MySQL Linux Backup Script
I’ve written the following script to backup the last closed historical partition and assosiated data tables for the Ignition historian on Linux. You can schedule this with cron tab and store the backups on a remote windows share or something pretty easily.
#!/usr/bin/python
import sys
import os
import datetime
import mysql.connector
from subprocess import call
from optparse import OptionParser
def main(argv):
	#	Setup command line argument parsing
	usage = "usage: %prog [options] directory"
	parser = OptionParser(usage=usage)
	parser.add_option("-u", "--user", dest="username", help="MySQL Username")
	parser.add_option("-p", "--password", dest="password", help="MySQL Password")
	parser.add_option("--host", dest="host", help="MySQL Host Address")
	parser.add_option("-d", "--database", dest="database", help="MySQL Database Name")
	(options, args) = parser.parse_args()
	if(len(args) != 1):
		parser.error("Error: Incorrect number of arguments")
	#	Read in arguments
	if(options.host is None):
		host = "127.0.0.1"
	else:
		host = options.host
	if(options.username is None):
		username = "root"
	else:
		username = options.username
	if(options.password is None):
		password = ""
	else:
		password = options.password
	if(options.database is None):
		database = "Historian"
	else:
		database = options.database
	basedir = args[0]
	backupdir = basedir + 'mysql.' + database + "." + str(datetime.date.today())
	#	Connect to MySQL
	db = mysql.connector.connect(
			host=host,
			user = username,
			passwd = password,
			database = database
	cursor = db.cursor()
	#	Check if the backups table exists.
	query = """
			SHOW TABLES WHERE tables_in_%s = 'sqlth_backups';
			""" % database
	cursor.execute(query)
	results = cursor.fetchall()
	# If there isn't a backups table, create it.
	if(len(results) < 1):
		print "Creating backups table."
		query = """
				CREATE TABLE `sqlth_backups` (
				  `backupid` int(11) NOT NULL AUTO_INCREMENT,
				  `target` varchar(255) DEFAULT NULL,
				  `actiontime` datetime NOT NULL,
				  `expires` datetime NOT NULL,
				  PRIMARY KEY (`backupid`)
				) ENGINE=InnoDB;
		db.commit()
	# end if
	#	Select the current history partition to avoid backing that up.
	query = """
			SELECT
				pname
			FROM sqlth_partitions
			WHERE
				end_time = (SELECT MAX(end_time) FROM sqlth_partitions);
	latestPartition = cursor.fetchall()[0][0]
	#	Select misc history tables and history partitions that haven't been backed up yet
	query = """
			SHOW TABLES
			WHERE
				tables_in_{db} LIKE 'sqlth%'
			OR (
				tables_in_{db} LIKE 'sqlt_data_%'
			AND
				tables_in_{db} not in (select distinct target from sqlth_backups)
			""".format(db=database)
	tableList = cursor.fetchall()
	# create a new directory for this set of backups
	os.system("mkdir %s" % (backupdir))
	#	For each table, back it up to it's own SQL file, then insert a record into the backups
	#	table to record the backup.
	queries = []
	for row in tableList:
		if(row[0] != latestPartition):
			print "Backing up " + row[0]
			cmd =  "mysqldump -h %s -u %s -p%s %s %s > %s/%s.sql" % (host, username, password, database, row[0], backupdir, row[0])
			os.system(cmd)
			query = "INSERT INTO sqlth_backups(target, actiontime) VALUES('%s', CURRENT_TIMESTAMP);" % row[0]
			queries.append(query)
	# end for
	print "Recording Backups in SQL"
	for query in queries:
	# end for
	#	Commit and close the database connection
	db.commit()
	cursor.close()
	db.close()
	#	Archive the backup to a .tar.gz and remove the temporary backup folder.
	print "Zipping Archives"
	os.system("tar -cvzf %s.tar.gz %s" % (backupdir, backupdir))
	os.system("rm -r %s" % (backupdir))
# end def
if __name__ == "__main__":
        main(sys.argv[1:])
Thanks for posting this Cody, this looks really useful :thumb_left:
