I have a named query in Ignition 8 like the following:
SELECT TagId FROM sn_tags_and_items where DomainId = :domainId and TagPath like :tagPath
where I pass domainId=99 and a tagPath=/my/tag/path
the query works correctly in Authoring/Testing window of the Named Query tool but as soon as I bind it to some page I am returned in the binding preview with a:
Error_Configuration("RuntimeException: Syntax Error on token: 'DIVIDE (Line 1, char 7)")
notice I have no DIVIDE in my query so I don't know where DIVIDE comes from, probably behind the lines some Ignition 8 escaping is involved.
Do you have quotes around the tag path you’re passing in? If not, SQL is taking your / in the tag path to be a division symbol, which is why you’re getting an error about DIVIDE.
Like others have said, if you show more information we can help you better.
I don't think so. The Named query parameter is in value mode, so it will not be parsed as SQL. The error also does not look like it comes from SQL, but from expression evaluation.
What log name do I have to increase debug level for? I tried putting everything containing "query" and "sql" in the name to debug level but I don't see any log related to the problem yet
When supplying a constant expression as a value in a binding, you have to use expression language quoting rules. (See the little fx icon…) For comparison, store your string in a custom string property and pass that instead.
