Named query in timer script
Getting an error when trying to call a named query from a client timer script. The script works when called from e.g. the script console, a button or another thing called from the UI Thread, just not from the timer script.
Here’s the error
  File "<module:project.core.smartcardio>", line 125, in authenticate
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Named query smartcardio/AuthenticateCard not found
	caused by GatewayException: Named query smartcardio/AuthenticateCard not found
	caused by GatewayFunctionException: Named query smartcardio/AuthenticateCard not found
Ignition v7.9.9 (b2018081621)
Java: Oracle Corporation 1.8.0_171
I tried adding the project name, which doesn’t work, as the error suggests its a gateway exception. That just generates another mapping error, similar to this
http://forum.inductiveautomation.com/t/cannot-coerce-value-named-query-path-into-type-interface-java-util-map/18042
Any suggestions on what’s wrong?
EDIT
Also tried to call it on the UI thread from the timer script, still the same.
