view.json (80.3 KB)
Zero matches found for timeRange.
Thank you for looking into this issue, I had been using Ignition at my previous employer for 5 years (obviously not as long using Perspective) and had never seen this before… I mean views function even though phantom params are populating, but I figured I should report this strange issue so it can be resolved. Thanks!
Apologies for the delay, but I was finally able to sit down and examine this issue. A quick examination of your view.json file immediately exposed the issue: the associated propConfig
entries for params are not being removed from the View when a param is deleted. I’ve opened an internal issue to get this fixed. A short-term workaround is to remove those entries by hand from the view.json file. I’ve manually repaired your view myself and attached it here. This view now displays the expected params:
To replace your copy of the View, you can either replace the view.json file within your file directory with what I have attached here, or you can follow these steps:
- Open the view.json file in your favorite text editor.
- copy the contents of the file to your clipboard.
- Open the View in question in your Designer.
- Hold Shift and right-click the view node in the Project Browser panel.
- Select “Paste JSON”.
view.json (79.8 KB)
