The 5/8/2020 Nightly Release of Ignition 8.0.13 introduces an overhaul to Tag Security. The primary goal of this overhaul was to get the Tag Permissions model to start using Security Levels, a powerful new hierarchical permissions model introduced in Ignition 8 and previously only used in Perspective. This overhaul is also an important step to make as we transition other parts of Ignition to use Identity Providers and Security Levels.
Some of the changes you will see:
The Security property set of a tag has 3 options:
Read Permissions: Defines the security levels required in order to read values from a tag
Read Only: Defines whether a tag is read-only or writable
Write Permissions (hidden if Read Only is enabled): Defines the security levels required in order to write values to a tag
A new configuration screen for Read and Write permissions which resembles the Perspective permissions configuration experience:
You no longer have to type out role names or security zones. The checkbox tree you are presented with will show you all of the security levels configured in the Gateway Config > Security > Security Levels page
You have the ability to set security by Role Only, Role + Security Zone or Security Zone Only.
You have the ability to require any or all the security levels you have selected
Any existing Tag Security will be migrated to the functional equivalent in the new model on upgrade. The same goes for tag imports from previous versions.
We hope that the changes benefit you and we welcome all feedback. If you do find an issue that you feel needs addressed, please let us know.
The permissions model seems a lot more complicated though (deeper nested JSON, or-ed and and-ed together).
Would there be an easier way to check if the current user is able to read or write a tag?
Or is there something coming to bind enabled/editable/visible/… properties to tag readability? Like a special expression perhaps?
It seems like a lot of work to get it right with all special cases, if that functionality could be added in one of the next versions.
I have same needs.
I have converted all my generated udt with the new tag permission format for Ignition 8.0.13+
For checking if write operation is authorized for a tag with scripting, you will had to read the tag properties writePermissions and readOnly and use something ugly like that to obtain roles and compare it to the logged user roles...
def getRoleFromTagPermission(permission):
Example :
"writePermissions": {
"type": "AnyOf",
"securityLevels": [
"name": "Authenticated",
"children": [
"name": "Roles",
"children": [
"name": "BIL_param",
"children": []
"name": "GTC_visu",
"children": []
"readPermissions": {
"type": "AnyOf",
"securityLevels": []
global strLib
strFct="getRoleFromTagPermission"
try:
result = []
if ((permission != None) and (permission != "")):
#<type 'com.inductiveautomation.ignition.common.auth.permissions.PermissionsConfig$AnyOfPermissionsConfig'>
#if type(permission)==AnyOfPermissionsConfig:
json = permission.toJsonTree()
if json != None:
if "securityLevels" in json:
securityLevels = json["securityLevels"]
if securityLevels != None:
if len(securityLevels)>0:
roles = securityLevels[0]["children"][0]["children"]
for role in roles:
result.append(role["name"])
except:
shared.commun.logger.logERROR(strFct=strFct,strLib=strLib,strLog="GTC_Tag")
return result
@jspecht
If there is a way to obtain the securitylevels of the user, there is an isAuthorized function to check the permission.
Assuming you have a list of the current vision user’s roles and zones, you could do something like this:
roles = ["Administrator", "Operator"]
zones = ["ZoneA", "ZoneB"]
securityLevelPaths = []
for role in roles:
securityLevelPaths.append(["Authenticated", "Roles", role])
for zone in zones:
securityLevelPaths.append(["SecurityZones", zone])
securityLevels = SecurityLevelConfig.fromPaths(securityLevelPaths)
At this point, you have securityLevels, so checking permissions would be like the first example I gave above.
Yes you can skip the security zones, but if your permissions require a specific security zone, isAuthorized() will return false.
Edit: if you do not provide a SecurityZones node or if you do provide it but it has no children, we assume the user falls back to the “Default” security zone. So if your permissions does require the “Default” zone then it could return true as long as the other security levels are satisfied in the permissions.
