I have a named query which is intended to log some batch information to a database. I have tested calling the query from a button event script using manually coded variables and it works as intended, so now I want to update it to be called from a tag change script, and to pass values from the PLC into the query.
But it seems like there must be a more efficient way to do it. There are quite a lot of values being logged here.
Is there a way to lump all the PLC tags into a dataset (without building a table on the screen) and just pass the dataset to the query?
Is there a way to read a bunch of tags and have them assigned to each named query parameter in the order they’re defined, instead of having to specify each tag and each query parameter individually by name?
Any other creative ideas on how I can streamline this?
I had to modify it slightly because system.tag.readBlocking() returns a qualified value, not just the tag value:
paths = ['ProductCode', 'Description', 'WeightSP', 'ActualWeight']
values = system.tag.readBlocking(["[default]CurrentBatch/{}".format(path) for path in paths])
values = [item.value for item in values]
parameters = dict(zip(paths, values))
system.db.runNamedQuery(MyProjectName, MyQuery, parameters)
This works, but I wondered if there’s a simpler way to use the system.tag.readBlocking function so that it only returns a list of the values, not the qualified values? Something like values = system.tag.readBlocking(["[default]CurrentBatch/{}".format(path) for path in paths]).value - though of course, that doesn’t work because the list itself has no value property, only the items in the list.
tagValues = [tag.value for tag in system.tag.readBlocking(["[default]CurrentBatch/{}".format(path) for path in paths])]
parameters = dict(zip(paths, tagValues))
