Perspective Alarm Status Table Initial Filter
When the Alarm Status Table first loads, it initially shows all alarms, even with a filter condition set in the designer. The filter does not take effect until a couple seconds after load. Is there a way to prevent this from happening? We filter alarms based on the logged in user, and they should not be able to see alarms that do not pertain to them (If they are quick, they can even acknowledge and shelve them).
Also, when an alarm is shelved, is there a way to filter these by the source? Currently all users can see all shelved alarms.
I’m having the same issue as you for the filters, but on the shelved alarms you should be able to filter those with the filterAlarms scripting function right?
