Perspective app white screen on iPhone 6 with iOS 12.5.3
We have a problem where every update after 8.1.4 doesn’t work on the Perspective applications on older iPhone 6 devices (which are updated to the newest iOS version available to them - 12.5.3). When I launch the app and log in, I’m given a white screen that does nothing, even if I refresh the page.
Will there be a fix for this going forward? I know of a facility that uses ~60 of these devices and it would be a shame if they had to stay on version 8.1.4 or buy newer devices.
There was a bug introduced in 8.1.6 which resulted in this, you say you are seeing it in 8.1.5 though? Could you double check that?
The bug fix should be included in 8.1.8 and is already available in the nightly releases.
Thanks,
Jonathan C
We haven’t tested out 8.1.5 but we do know 8.1.4 worked. We updated from 8.1.4 to 8.1.6 (and then 8.1.7) and started seeing that bug on certain devices.
Its good to know that there will be a resolution for this! Thanks @jcoffman
I had something similar on a different browser, and the update fixed it for me
