Hey I’ve just downloaded Ignition 8.0.12 and it work now .
I was on 8.0.10 before if it help.
I have an other issue on Perspective with the Map component.
I’ve added elements in Layers/ui/marker and I’m trying to change the icon path in the element.
I’ve added: /system/images/NZ Controls/Icons/64/Water drop_blue.png but it doesn’t take it.
When I add an image component with the same image path it take it no problem.
Does the icon path parameter expect something else in it?
Thanks,
