Along those same lines: When I take the existing markers from the Map like this:
markers = self.getSibling("Map").props.layers.ui.marker
I can view and manipulate. However, the append method doesn't seem to work. For example, I'm reading an array with a length of 2 (i.e. two markers) and when I try to appends like this (from the example above):
markers.append({'lat':40.413521,'lng':-91.401863,'opacity':1,'riseOnHover':False,'riseOffset':250,'icon':icon,'tooltip':tooltip,'popup':popup})
I get the error:
java.lang.ArrayIndexOutOfBoundsException: Index 2 out of bounds for length 2
However, if I start with an empty list I can append. The Map component appears to be using a PyArray however according to the documentation I've seen this should behave like the list's append method. I must be missing something.
About the marker Icons: I can change the marker icon and size, however seem to be unable to change the color.
icon = {'path':'material/location_on','size':{"width":40,"height":60},'color':'red'}
As far as the color property goes, I've tried RGB, Hex integer and java.awt.Color values all seem to be ignored. I did notice that the Icon component has a color property that seems to be unicode.
