Perspective Status Chart
Looking for something like Status Chart in perspective, similar to vision, any idea what should I do? tx.
I haven’t had a chance to use it myself yet, but there is a Ribbon Chart on the Ignition Exchange that may be what you’re looking for.
I couldn’t make use of this, not sure what I am doing wrong,
it’s a zip file, I imported that as a project, and it contains an empty page,
I’m using 8.0.16, which might be the cause (it needs 8.0.15), or I am doing something wrong,
Nevertheless, thanks for the reply.
@CTavakoli, you might have to extract the zip first. IIRC, the project zip is inside the downloadable zip.
Thanks, still the same though
Works for me. Just tested on 8.1.0-RC3.
Be sure to read the readme.txt in ribbon_chart.3.0.0\Other\Ribbon Chart\readme.txt
Try extracting the Ribbon Chart.3.0.0.zip, then in that extracted folder, go to Other and extract Ribbon Chart.zip. Once that’s extracted, you should be able to go to File–>Import in Ignition and select the Ignition Import.zip from that folder. That should show up with 2 perspective views to import.
Thank you all, it is working.
Hi everyone,
I was wondering if someone could point me in the right direction on how to get this Ribbon chart to work.
I have managed to get the dataset converted into the correct structure and they are split up into the correct events.
I have also added the correct amount of modes into the modes section.
My problem is that when the chart transitions you can see the correct stages/colors with in the bar but they are squeezed by the first event to nothing and only the first event is seen.
Has anybody come across this problem before?
Regards
Richard
