I have a similar setup to you so have put together a couple of functions to do what you need, it is perhaps a nasty workaround but it works. May need further error checking, I’m going to start displaying this state pie chart myself so will update if I find any problems.
I have a simple state that is 0 - 3. I record the state number in the historical db. I then have a dataset tag containing the description of each state number.
0 Fault / Stopped
1 Running
2 Discharge High
3 Infeed Low
I have two functions, call the first to get the total minutes for each state over the desired period.
Call the second to substitute the state numbers for the descriptions.
def historyduration(tag,startdate,enddate):
ColumnNames = ["t_stamp","code"]
hds = system.tag.queryTagHistory(paths=[tag], startDate=startdate, endDate=enddate, columnNames=ColumnNames, aggregationMode="MinMax", returnFormat='Wide', noInterpolation=True, ignoreBadQuality = 1)
ds = []
dsheader = ['Code','Duration']
#get number of seconds between each event change
for row in range(hds.rowCount):
#first row start time is start of query
if row == 0:
valtime_start = startdate
valtime_end = hds.getValueAt(row,'t_stamp')
valdiff = system.date.secondsBetween(valtime_start, valtime_end)
valcode = hds.getValueAt(row,'code')
#all other rows except last
if (row > 0) and (row < hds.rowCount-1):
valtime_start = hds.getValueAt(row,'t_stamp')
valtime_end = hds.getValueAt(row+1,'t_stamp')
#last row end time is end of query
if row == hds.rowCount - 1:
valtime_end = enddate
#convert seconds to minutes
valdiff = (valdiff * 1.00) / 60 * 1.00
ds.append([valcode,valdiff])
ds2 = system.dataset.toDataSet(dsheader,ds)
#sort by event code
sds2 = system.dataset.sort(ds2,'Code')
#lastvalue needs a value
lastvalue = -1
duration=0
fds2 = []
#group each like event together and add duration
for row in range(sds2.rowCount):
value = sds2.getValueAt(row,'Code')
thisduration = sds2.getValueAt(row,'Duration')
#if this is a new event, append last event details
if value != lastvalue and lastvalue > -1:
fds2.append([lastvalue,duration])
duration = 0
#if this is the last row add duration and append
if row == sds2.rowCount - 1:
duration = duration + thisduration
fds2.append([value,duration])
lastvalue = value
return system.dataset.toDataSet(dsheader,fds2)
def codereplace(ds,descriptions):
#substitute code for description in dataset
nds = []
ndsheader = ['State','Duration']
for row in range(ds.rowCount):
code = ds.getValueAt(row,'Code')
duration = ds.getValueAt(row,'Duration')
for row2 in range(descriptions.rowCount):
if code == descriptions.getValueAt(row2,'Code'):
description = descriptions.getValueAt(row2,'Description')
nds.append([description,duration])
break
return system.dataset.toDataSet(ndsheader,nds)
Hope that helps.
