I have a project where the power tables are populated dynamically from a database and this is working fine. They then requested the ability to add dynamic drop-downs in the table with separate options. I used the solution from the following post modifying as needed.
This works well, thank you David! I am having a problem trying to implement a listener with the dynamic JComboBox and I have never used this before so any help is appreciated. The issue I am trying to solve is when a user selects an option then clicks another component the selection is not written to the underlying table dataset. Here is the code in the configureEditor.
from javax.swing import AbstractCellEditor,JComboBox, JTextField
from javax.swing.table import TableCellEditor
from java.awt.event import ItemListener, ItemEvent
# used to listen to item change events in the combobox
class MyItemListener(ItemListener):
# Constructor
def __init__(self, table, value, rowIndex, colIndex,editor):
self.table = table
self.rowIndex = rowIndex
self.colIndex = colIndex
self.value = value
#self.options = {'':0, 'OPEN':1, 'CLOSED':2}
self.editor = editor
# this is fired when the combobox changes
def itemStateChanged(self, event):
if (event.getStateChange() == ItemEvent.SELECTED):
item = event.getItem()
# convert the new value to the index. E.g. OFF -> 0
if type(self.editor) is JComboBox:
newValue = self.editor.getSelectedItem()
else:
newValue = self.editor.getText()
# if item in self.options:
# newValue = self.options[item]
# create a new dataset with the updated value
newDS = system.dataset.setValue(self.table.data, self.rowIndex, self.colIndex, newValue)
self.data = system.dataset.setValue(self.data, rowIndex, colIndex, newValue)
# write back to the source property
# update this to whereever your master data is
self.table.data = newDS
rootSelf = self
class myTableCellEditor(TableCellEditor, AbstractCellEditor):
def __init__(self, tableComponent):
self.table= tableComponent
self.editor = None
def getTableCellEditorComponent(self, table, value, isSelected, rowIndex, vColIndex):
def setJComboBox(ds):
ddList = ['']
values = [row['ddValue'] for row in system.dataset.toPyDataSet(ds)]
ddList.extend(values)
self.editor = JComboBox(ddList)
if rowIndex == 0: # Collar
ds = rootSelf.ddCollar
setJComboBox(ds)
elif rowIndex == 1: # Holes
ds = rootSelf.ddHoles
setJComboBox(ds)
elif rowIndex == 3: # Edge Slitters
ds = rootSelf.ddSlitter
setJComboBox(ds)
elif rowIndex in [6,7]: # Pressure
ds = rootSelf.ddPressureBar
setJComboBox(ds)
else:
self.editor = JTextField()
return self.editor
def getCellEditorValue(self):
else:
return newValue
if colName == "User Defined":
m = myTableCellEditor(self)
return {"editor":m}
