Problem adding variable in email body
Good morning,
I’m able to send my report by email when I have a tag change, it work perfectly.
What I’m trying to do is to add a variable in the body, in this case the email is not sent.
value = newValue.value
if value == 1:
    body = "TagTestValue: "  #If I just add this in the body, it works
    # body = "TagTestValue: " + system.tag.read("[default]TagTest").value  # With this line, adding the tag.read in the body, the email is not sent and I have none error in the console
	system.report.executeAndDistribute(path="MyPath", project="MyProject", action= "email",
	actionSettings = {"to":["myEmail"], "smtpServerName":"EmailSetting", "from":"myCompany", "subject":"MySubject", "body":body})
Where’s the mistake?
Thank you very much.
if value == 1:
    variable = system.tag.read("[default]TagTest")
    variableQV = variable.value
    body = "TagTestValue: " +str(variableQV)
Thanks for your help Matrix_Engeneering. It works great.
One question about this: I see that if I try to send a variable DateTime and it has a correct value, the email is sent. If the variable DateTime has not a correct value (for example is “null”), the email is not sent.
Is there a way to check if the variable has a correct value, so I can manage the email body in the properly way?
Thank you very much
Where are you getting DateTime from, a tag?
You can try something like this maybe changing -1 to “None”
x = system.tag.read("[System]Gateway/CurrentDateTime")
print x
QV = x.value
print QV
if QV != -1:
	print "send email"
	#Put Your Send Email Code Here
Hi Matrix_Engineering and thanks for your reply.
I try to explain what I need to do, sorry for the english: I have a report that is sent when a batch is finished, and in this report I have a StartTime and an EndTime tags that I fill when this batch starts and ends.
At the end of the batch I send an email with process data and trends, and in the body I add the StartTime and EndTime with a specific format
startBatch = system.tag.read([default]myPath).value
startBatch = system.date.format(startBatch , dd MMMM yyyy HH:mm)
If the DateTime have correct values, the email is sent, but I've seen that if one or both the DateTime tags have no value ("Null"), the email is not sent, so I would check if the DateTime is valid before to add it in the body, in the case is not valid I will manage it in another way.
I try this
if QV != -1:
if QV != "None":
if QV != "Null":
but in all the cases the email is not sent.
Thanks again for your help.
Yes because you don’t have QV in your script.
I would change so your variables are unique (for the formatted):
startBatchF = system.date.format(startBatch , dd MMMM yyyy HH:mm)
Then when you go to add the variable to email, make sure to typecast as string:
str(startBatchF)
When checking != None etc, you don’t need to add quotes around None and Null
None is special in Python & Jython. You are supposed to test for it with the is keyword. Or is not. Like so:
if startBatch is None:
    # log that the batch interval is invalid...
Thanks everybody for the help.
I change the script as you suggest and it works perfectly!
