I’m using a propertyChange in a template, the problem that I’m that this script executes when opening the window where the template is located.
‘value’ is the value of a ‘numeric label component’
if event.propertyName=='value':
event.source.parent.getComponent('Timer').running=1
can someone help me to fix this. thanks
What is the problem? Every bound property changes on startup (window or template) when the initial value arrives.
if event.propertyName == 'value' and not event.propertyName == 'componentRunning':
event.source.parent.getComponent('Timer').running = 1
Not going to work, the OP is already filtering out componentRunning events; those two conditions are by definition mutually exclusive as all events happen independent of one another
Yeah, I see what you are saying about the mutual exclusion.
I forgot to say that I have not associated any udt to the template. I associate the value with a parameter, in which from a window I paste the path of the tag.
I have made a test of associating a udt with the template, and associating the value with the property of the udt, now the script is not executed every time I open the window where the template is, but every time I access the application from the client ( much better than in the previous case).
is there a way to ignore the initial value that the template has?
Thank you very much everyone for the help.
I followed the instructions but without result. I’m going to keep trying. any other solution is appreciated. thanks you
Have You,already, fixed it?
@pturmel you can upload a project where it shows an example, thanks you
