[QUESTION] MSSQL Integrated Security Authentication
Do you still need the sqljdbc_auth.dll added to the Ignition lib folder to use Integrated Security with MS SQL Server for Ignition 8? If so, is the dll version for Ignition 8 the same as the one listed in the link below?
https://support.inductiveautomation.com/index.php?/Knowledgebase/Article/View/5/0/microsoft-sql-server-mssql-connection-guide-for-ignition
Newer DLLs are available in the JDBC zip files you can download from Microsoft: https://docs.microsoft.com/en-us/sql/connect/jdbc/download-microsoft-jdbc-driver-for-sql-server
There’s nothing changed that would make them not needed any more.
Thanks for the link to the updated files and the quick response!
