Is there a way to open a file and transfer it directly into a table on a timed script every 1 minute or so.
I have a constantly updating .csv file and need to import the values so I can use them as temperature readings in my project. I am using the following script to access the file which works but I need an automatic system that is constantly updating.
# Import Python's built-in csv library.
import csv
# Ask the user to find the CSV in the local file system.
path = system.file.openFile("csv","C:\Users\Owner\Google Drive\Dobsons\Programming\Backup.Recorder Data Mar 2017.csv")
#Create a reader object that will iterate over the lines of a CSV.
# We're using Python's built-in open() function to open the file.
csvData = csv.reader(open(path))
# Create a List of strings to use as a header for the dataset. Note that the number
# of headers must match the number of columns in the CSV, otherwise an error will occur.
# The simplest approach would be to use next() to read the first line in the file, and
# store that at the header.
header = csvData.next()
# Create a dataset with the header and the rest of our CSV.
dataset = system.dataset.toDataSet(header ,list(csvData))
# Store it into the table.
event.source.parent.getComponent('Power Table').data = dataset
Can you not set up a connection to your temperature sensors with tags and add history to them to log the data in the db? Then just query the data with a table.
While I agree that logging it to a database is the best endgame, the problem is (judging from the filename and the OP saying so) that the csv is appended to and not a new file for every reading. You would then need to filter out whatever lines were already logged to avoid duplicates. Let’s start with his original request and go from there.
I modified your script to grab the latest file in the directory and store it an a dataset tag.
# Import libraries
import os, glob, csv
# Set pathName. Note the asterisk.
pathName ='C:\Users\Owner\Google Drive\Dobsons\Programming\Backup.Recorder*'
fileList = glob.glob(pathName)
lastFile = max(fileList, key = os.path.getmtime)
# Create a reader object that will iterate over the lines of a CSV.
csvData = csv.reader(open(lastFile))
# Get headers
# Store it into the tag.
system.tag.write('[default]path/to/dataset/tag', dataset)
I got most of the code working with a bit from each.
I now have an issue changing the folder I access the data from dynamically.
As below I have been able to write the Year and Day into the correct format but now need to work it into the folder address.
Any Ideas?
“”"Date = system.date.now()
Year = system.date.format(Date, “yyyy”)
Day = system.date.format(Date, “MMMdd”)
system.tag.write(‘CDTest’, Year)
system.tag.write(‘CETest’, Day)
Triple-backquotes on a line before and a line after the code section. The marker before the code block can optionally indicate which language is involved, in case autodetection fails. This forum is built on Discourse, which has a page on the details, with links to even more details:
When I try to run the script below I get this error
Error
File "<event:mouseClicked>", line 14, in <module>
_csv.Error: line contains NULL byte
Ignition v7.9.5 (b2017111615)
Java: Oracle Corporation 1.8.0_211
Script
# Import libraries
pathName ='C:\Users\jshaffer\Desktop\PARTS ROOM 2019-2020_r1*'
# Get headers
system.tag.write('[default]PartsRoomDataset', dataset)
Hello, my question is can I import the .csv file to the Table Row 1 instead of the header.
I am using the power table. The header data get replaced every time.
FYI, my csv file does not contain header name.
I do not want the data to overwrite my table header.
Hello, may I know can I use the above script at client event Tag Change script ?
My objective is when my tag change, I should import the dataset from .csv to a Table.
My table is in the template (template name is SummaryReport) at directory Templates/Report1/
I then place the template to a window (window name is Report) with directory /PopUp Windows/Summary_Report/Data1/
Referring to below, am I missing something ?
when i read from the .csv file, is it correct to have the value as string ? following your suggestion, read from .csv to dataset tag, then bind the table to the tag. I noticed my table column type is string. I would need to total up the values of each row on the table, any idea ?
