This is an example to make your bar chart colors customizable using the JFree Chart API in JYTHON.
This is executed under the chart properties => edit script.
from java.awt import Color
a = 1
#gets the underlying dataset in the chart
ds = chart.getPlot().getDataset()
#print ds.rowCount
# gets the plot
plot = chart.getCategoryPlot()
#gets the Barrenderer object
renderer = plot.getRenderer()
#Loop Through dataset and check value and assign series colors
for row in range(ds.rowCount):
print row
value = float(ds.getValue(row, 0))
print value
if value >= 100.0:
print 'Row %d should be green'%row
renderer.setSeriesPaint(row, Color.GREEN)
if value <= 99.9 and value >= 88.0:
print 'Row %d should be yellow'%row
renderer.setSeriesPaint(row,Color.YELLOW)
if value <= 87.9:
print 'Row %d should be red'%row
renderer.setSeriesPaint(row,Color.RED)
else:
a = 0
This sets the series colors. It doesn’t set the color based on the value of the same series. I am trying to change the color based on the value of the bar in the same series. Any suggestion…thanks
It didn’t work for me in a bar chart script in report module. (ignition 7.9.9)
My code below in def configureChart(data,chart) :
from org.jfree.chart.renderer.category import BarRenderer
class myBarRenderer(BarRenderer):
def getItemPaint(self, row, column):
v = chart.getCategoryPlot().getDataset().getValue(row, column)
if v < 0:
return Color.green
else:
return Color.red
plot.setRenderer(myBarRenderer())
Error is :
File “function:configureChart”, line 13, in configureChart
java.lang.ClassCastException: java.lang.ClassCastException: org.jfree.chart.plot.XYPlot cannot be cast to org.jfree.chart.plot.CategoryPlot
