Scale image in canvas
I like the concept of using the canvas to generate images stored in a database. How could we resize the image to fit inside the canvas?
I have this in my repaint script:
[code]from javax.imageio import ImageIO
from java.net import URL
selectedID = event.source.parent.selectedID
blobData = system.db.runQuery(“SELECT partPicture FROM PartsPicture WHERE partID = ‘%s’” % selectedID)
g = event.graphics
if len(blobData) > 0:
data = blobData[0][0]
# open up a temp file
# store the file name in a custom property on the paintable canvas
# the paintable canvas repaint event will use this as input stream
filename = system.file.getTempFile(“jpg”)
system.file.writeFile(filename, data)
urlFile = ‘file:%s’ % filename
event.source.parent.getComponent(‘Paintable Canvas’).fileName = urlFile
#Note: custom property on paintable canvas ‘fileName’ [string]
url = event.source.fileName
imageStream = URL(url)
image = ImageIO.read(imageStream)
#### Scale graphics to actual component size (doesn't do anything for me)
dX = (event.width-1) / 100.0
dY = (event.height-1) / 100.0
g.drawImage(image, 1, 1, event.source)
g.scale(dX,dY)[/code]
You can scale the image in the call to drawImage. Here’s what is use (bytes is the blob read from the database, you don’t need a temp file):
	width = event.source.getWidth()
	height = event.source.getHeight()
	try:
		from java.io import ByteArrayInputStream
		bais = ByteArrayInputStream(bytes)
		image = ImageIO.read(bais)
		bais.close()
		imgRatio = float(image.getWidth())/float(image.getHeight())
		if (imgRatio > 0):
			finalWidth = int(height * imgRatio)
			if (finalWidth > width):
				finalWidth=width;
			finalHeight = int(finalWidth / imgRatio)
			print imgRatio
		else:
			finalWidth = width
			finalHeight = height
			print 'No ratio'
		y = (height-finalHeight) / 2
		g.drawImage(image,1,y,finalWidth,finalHeight,event.source)
	except:
		g.drawString(u'Bild kann nicht angezeigt werden', 10, height/2)
The image variable in the code returns a BufferedImage which has an inherited method called getScaledInstance. You can use this to scale the image. In this example, I scale the width of the image to 320 pixels and maintain the aspect ratio for the height (a 640x480 image will be scaled to a 320x240 image):
####BEGIN SCALED IMAGE####
scaledImage = image.getScaledInstance(320,-1,0)
event.graphics.drawImage(scaledImage, 0, 0, event.source)
####END SCALED IMAGE####
From a deleted REPLY to this thread:
Just comment out the "try, except" to see what the exact error is:
blobData = system.db.runQuery("SELECT partPicture FROM PartsPicture WHERE partID = '%s'" % selectedID)
g = event.graphics
      bytes = blobData[0][0]
      #try:
      bais.close()
      if (imgRatio > 0):
            finalWidth=width;
         print imgRatio
      else:
         finalWidth = width
         print 'No ratio'
      #except:
      #g.drawString(u'Bild kann nicht angezeigt werden', 10, height/2)
[quote=“adamaustin”]The image variable in the code returns a BufferedImage which has an inherited method called getScaledInstance. You can use this to scale the image. In this example, I scale the width of the image to 320 pixels and maintain the aspect ratio for the height (a 640x480 image will be scaled to a 320x240 image):
[code]
[/code][/quote]
Thanks, this works well for me!
