system.net.httpClient() no longer working in script console
I current use the script console to test a REST wrapper implemented in Ignition using the system.net.httpclient.
Since upgrading from 8.0.7 to 8.0.11 (and subsequently 8.0.12) trying to create the httpclient fails inside the script console.
# Create the JythonHttpClient
client = system.net.httpClient()
Java Traceback:
  File "<input>", line 2, in <module>
	at com.inductiveautomation.ignition.common.script.builtin.AbstractNetUtilities.httpClient(AbstractNetUtilities.java:498)
	at jdk.internal.reflect.GeneratedMethodAccessor37.invoke(Unknown Source)
java.lang.NoClassDefFoundError: java.lang.NoClassDefFoundError: Could not initialize class com.inductiveautomation.ignition.common.script.PyArgParser
	at org.python.core.Py.JavaError(Py.java:552)
	at org.python.core.Py.JavaError(Py.java:543)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:521)
	at org.python.core.PyObject.__call__(PyObject.java:464)
	at org.python.core.PyObject.__call__(PyObject.java:468)
	at org.python.pycode._pyx777.f$0(<input>:2)
	at org.python.pycode._pyx777.call_function(<input>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.Py.runCode(Py.java:1614)
	at org.python.core.Py.exec(Py.java:1658)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:605)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:593)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class com.inductiveautomation.ignition.common.script.PyArgParser
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	... 19 more
Edit:
Followed advice from System.gui.transform error and reinstalled designer. It seems to have fixed it.
3 posts were split to a new topic: system.net.httpClient issue on particular machine
