System.serial UnsatisfiedLinkError (missing library?)
Fresh install of Ignition 7.5.1, added the following modules:
Serial Support Client 1.5.1 (b29)
Serial Support Gateway 1.5.1 (b29)
Created a button and added the following:
system.serial.openSerialPort('/dev/ttyUSB0')
Pressing the button results in the following:
ERROR [ActionAdapter-AWT-EventQueue-0] <HTML>Error executing script for event:&nbsp;<code><b>actionPerformed</b></code><BR>on component:&nbsp;<code><b>Button</b></code>.
  File "<event:actionPerformed>", line 14, in <module>
	at Serialio.SerialPortLocal.SerOpenPort(Native Method)
	at Serialio.SerialPortLocal.open(SerialPortLocal.java:317)
	at Serialio.SerialPortLocal.<init>(SerialPortLocal.java:287)
	at com.inductiveautomation.ignition.modules.serial.scripting.SerialScriptModule.openSerialPort(SerialScriptModule.java:199)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at java.lang.reflect.Method.invoke(Method.java:597)
java.lang.UnsatisfiedLinkError: java.lang.UnsatisfiedLinkError: Serialio.SerialPortLocal.SerOpenPort(LSerialio/SerialConfig;)I
	at org.python.core.PyException.fillInStackTrace(PyException.java:70)
	at java.lang.Throwable.<init>(Throwable.java:181)
	at java.lang.Exception.<init>(Exception.java:29)
	at java.lang.RuntimeException.<init>(RuntimeException.java:32)
	at org.python.core.PyException.<init>(PyException.java:46)
	at org.python.core.PyException.<init>(PyException.java:43)
	at org.python.core.Py.JavaError(Py.java:481)
	at org.python.core.Py.JavaError(Py.java:474)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
	at org.python.core.PyObject.__call__(PyObject.java:387)
	at org.python.core.PyObject.__call__(PyObject.java:391)
	at org.python.pycode._pyx17.f$0(<event:actionPerformed>:14)
	at org.python.pycode._pyx17.call_function(<event:actionPerformed>)
	at org.python.core.PyTableCode.call(PyTableCode.java:165)
	at org.python.core.Py.runCode(Py.java:1261)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:539)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:155)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:266)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
	at $Proxy14.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
	at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
	at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
	at java.awt.Component.processMouseEvent(Component.java:6288)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
	at java.awt.Component.processEvent(Component.java:6053)
	at java.awt.Container.processEvent(Container.java:2041)
	at java.awt.Component.dispatchEventImpl(Component.java:4651)
	at java.awt.Container.dispatchEventImpl(Container.java:2099)
	at java.awt.Component.dispatchEvent(Component.java:4481)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
	at java.awt.Container.dispatchEventImpl(Container.java:2085)
	at java.awt.Window.dispatchEventImpl(Window.java:2478)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:643)
	at java.awt.EventQueue.access$000(EventQueue.java:84)
	at java.awt.EventQueue$1.run(EventQueue.java:602)
	at java.awt.EventQueue$1.run(EventQueue.java:600)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:98)
	at java.awt.EventQueue$2.run(EventQueue.java:616)
	at java.awt.EventQueue$2.run(EventQueue.java:614)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:613)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: java.lang.UnsatisfiedLinkError: Serialio.SerialPortLocal.SerOpenPort(LSerialio/SerialConfig;)I
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
	... 49 more
When I originally tried this I had code that did a full configuration, open, write, read, close. This was throwing exactly the same exception, but also included a message complaining that it could not find the libLux86_64bit library. Unfortunately, I am unable to reproduce the error with this extra text.
I cannot find any reference to libLux86 anywhere, so I would guess it is supposed to be supplied by the serial module.
Any ideas?
Thanks.
This is the extra text that I was talking about…
Serialio Library: version 10.0.4: build 9212 Copyright (c) 1996-2009 Serialio.com, All Rights Reserved. os.name="Linux" os.arch="amd64" java.lang.UnsatisfiedLinkError: no libLux86_64bit in java.library.path: Check that native library libLux86_64bit is in proper directory
I’m finding it hard to reliably get this to appear- it seems that it is detached from the exception in some way and only runs once per session or something.
There is a bug in the native library loader for 64-bit linux. I’ve already fixed it, should work in the next release. Sorry about that.
Thanks. In the meantime, is there a workaround? I could easily make the file available if I knew where it is now and where the loader was searching for it.
The latest 7.5.2 beta (available in the downloads section of website) has the fix included.
Using 7.5.2-beta4, I get errors when starting the designer:
INFO  [main-Designer-Startup] Starting module: Serial Support Client [+7361]
ERROR [NativeLoader-Designer-Startup] Error loading SerialIo native library.
java.lang.NullPointerException
	at org.apache.commons.io.IOUtils.copyLarge(IOUtils.java:1383)
	at org.apache.commons.io.IOUtils.copy(IOUtils.java:1357)
	at com.inductiveautomation.ignition.modules.serial.SerialNativeLoader.loadNative(SerialNativeLoader.java:64)
	at com.inductiveautomation.ignition.modules.serial.SerialNativeLoader.load(SerialNativeLoader.java:49)
	at com.inductiveautomation.ignition.modules.serial.SerialSupportDesignerHook.startup(SerialSupportDesignerHook.java:18)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:2353)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1056)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:968)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler$1.run(IgnitionDesigner.java:379)
	at java.lang.Thread.run(Thread.java:662)
ERROR [main-Designer-Startup] Error starting up module Serial Support Client
	at com.inductiveautomation.ignition.modules.serial.SerialNativeLoader.load(SerialNativeLoader.java:52)
system.serial.openSerialPort still results in:
Please let me know if there is anything more I can do to help fix this.
Thanks.
Apologies… I didn’t actually push the changeset that fixed this. :blush:
I also got this error when calling
system.serial.openSerialPort('/dev/ttyAMA0')
Ignition v7.9.9
Serial Support Client 4.9.10 Trial
Rasberry pi 4.14.79-v7
  File "<event:keyPressed>", line 58, in <module>
	at Serialio.SerialPortLocal.open(SerialPortLocal.java:369)
	at Serialio.SerialPortLocal.<init>(SerialPortLocal.java:339)
	at com.inductiveautomation.ignition.modules.serial.scripting.SerialScriptModule.openSerialPort(SerialScriptModule.java:193)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.python.core.Py.JavaError(Py.java:495)
	at org.python.core.Py.JavaError(Py.java:488)
	at org.python.pycode._pyx4.f$0(<event:keyPressed>:97)
	at org.python.pycode._pyx4.call_function(<event:keyPressed>)
	at org.python.core.Py.runCode(Py.java:1275)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:180)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:271)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy21.keyPressed(Unknown Source)
	at java.awt.AWTEventMulticaster.keyPressed(AWTEventMulticaster.java:250)
	at java.awt.Component.processKeyEvent(Component.java:6493)
	at javax.swing.JComponent.processKeyEvent(JComponent.java:2832)
	at java.awt.Component.processEvent(Component.java:6312)
	at java.awt.Container.processEvent(Container.java:2236)
	at java.awt.Component.dispatchEventImpl(Component.java:4891)
	at java.awt.Container.dispatchEventImpl(Container.java:2294)
	at java.awt.Component.dispatchEvent(Component.java:4713)
	at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
	at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:806)
	at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1074)
	at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:945)
	at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:771)
	at java.awt.Component.dispatchEventImpl(Component.java:4762)
	at java.awt.Window.dispatchEventImpl(Window.java:2750)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
	at java.awt.EventQueue$4.run(EventQueue.java:731)
	at java.awt.EventQueue$4.run(EventQueue.java:729)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
	... 48 more
Ignition v7.9.9 (b2018081621)
Java: Oracle Corporation 1.8.0_65
We don’t have support for ARM with the serial module, unfortunately.
Thanks Kevin. Is there any way to get support for ARM?
I’m guessing that using the pyserial library is also not supported, given that I tried and received an import error indication ā€œNo Java Communications API implementation foundā€ (it’s looking for javax.comm or gnu.io)
And it looks like adding those libraries or anything else like jSerialComm library, for example, would not support client access anyway…
I’m not sure of any workarounds other than trying to build your own module to do serial access.
I think we have a ticket on our end for upgrading the serial library to a version that supports ARM if there’s on available from the vendor.
Okay, that wasn’t too difficult. Your documentation is pretty good! Using jSerialComm.
First time I've ever heard that, lol
edit: meant SDK docs, our Ignition docs are pretty good.
can you post the link to adding 3rd party Java libraries like jSerialComm
I followed the SDK documentation for making Designer/Client modules.
Just wrote a small class to expose the jSerialComm library and added it to the script manager. Not sure how correct it is, but it works just fine ĀÆ\_(惄)_/ĀÆ
I’m getting these unsatisfied link errors with v7.9.11 64-bit in both Windows 7 and Linux. Is this known and perhaps fixed in a later 7.9.x ?
If you get the errors but it still works then yes, it was a known/expected issue - the old serial library did its own System.loadLibrary call in a static initializer that would fail and we did our own explicit System.load against the known location for the library.
Hah! The error threw me off. It is in fact working. (:
(Planning to push them to latest 7.9 early this fall. Then 8.1 in the spring.)
