I have connected a Vlinx RS232 to Ethernet Server to Ignition.
I can get the Serial Data string when i set the driver up to be of Message type Character Based.
It seems that i can only use the keyboard characters as a delimiter here.
What i require here is the ASCII Hex value for line Feed (CR = 0xD(Hex)).
How can i get the TCP Driver to use the CR Carriage Retrun instead of normal characters.
Thanks for the help guys.
BTW this is used to connect a Weighing Scale to the system.
If you mean something like \r\n being the delimiter, yes that should work. But there’s no syntax or functionality for allowing the logical OR of different delimiters.
