This project works correctly in the designer but does not work in the runtime. This is similar to this post: ERROR(500): Error executing function 'RunQuery': The current user does not have the required roles for this operation
The problem I’ve encountered is that even after following the listed solution and enabling the permissions, the problem persists.
Open the client diagnostics (Ctrl + Shift + F7) and copy the error(s) you get opening the window from the console tab.
Creating frame. extendedState=6, bounds=java.awt.Rectangle[x=0,y=0,width=1920,height=1080]
11:05:25.073 [Thread-10] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Updated login state. Logged in? true, Username: PEIgnition, Roles: [Administrator, Root], Security Zones: null
11:05:25.124 [Thread-10] INFO ignition.TagManager.Gateway - Starting up polling tag manager, polling rate: 250 ms
11:05:25.411 [Thread-10] INFO com.inductiveautomation.reporting.client.ReportingClientHook - Starting up Reporting Module. Mode: Trial
11:05:26.284 [AWT-EventQueue-2] INFO vision.App - Starting Up...
11:05:26.681 [AWT-EventQueue-2] WARN Vision.Binding.SQLPropertyAdapter - Error running query:
SQLQuery(query=SELECT DISTINCT working_fluid FROM tank_inventory, database=)@0ms
On: Tank_Level.Root Container.Fluid_drop.data
java.lang.Exception: Error running query:
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:308)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing function 'RunQuery': The current user does not have the required roles for this operation.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runLimitQuery(GatewayInterface.java:819)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runQuery(GatewayInterface.java:789)
at com.inductiveautomation.factorypmi.application.gateway.SQLQuery.execute(SQLQuery.java:50)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.execute(QueryManager.java:657)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$Query.access$500(QueryManager.java:630)
at com.inductiveautomation.factorypmi.application.gateway.QueryManager$QueryExecutor.run(QueryManager.java:306)
... 1 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: The current user does not have the required roles for this operation.
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:403)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:518)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
at java.lang.Thread.run(Thread.java:844)
11:05:26.686 [AWT-EventQueue-2] WARN Vision.Binding.SQLPropertyAdapter - Error running query:
SQLQuery(query=SELECT * FROM tank_level WHERE tank_id = 0, database=)@0ms
On: Tank_Level.Root Container.Levels.data
11:05:26.690 [AWT-EventQueue-2] WARN Vision.Binding.SQLPropertyAdapter - Error running query:
SQLQuery(query=SELECT * FROM tank_inventory WHERE location = 'North Dakota' AND owner = 'austin' AND working_fluid = 'methanol', database=)@0ms
On: Tank_Level.Root Container.Inventory.data
11:05:26.694 [AWT-EventQueue-2] WARN Vision.Binding.SQLPropertyAdapter - Error running query:
SQLQuery(query=SELECT DISTINCT location FROM tank_inventory, database=)@0ms
On: Tank_Level.Root Container.Location_drop.data
11:05:26.697 [AWT-EventQueue-2] WARN Vision.Binding.SQLPropertyAdapter - Error running query:
SQLQuery(query=SELECT DISTINCT owner FROM tank_inventory, database=)@0ms
On: Tank_Level.Root Container.Owner_drop.data
Did you enable legacy permissions access (not recommended, as it's insecure) or did you populate the 'required client roles' for legacy database access? If the latter, then the logged in user doesn't have the role specified. If you did the former, then make sure the client has actually updated, or that you're in the correct project.
This solved my problem. The client simply had not been updated.
Thank you for your assistance!
I'm having a similar problem, and I've attempted to look at the items suggested in the previous messages. Still not able to get the table to populate in the client, but it does show data in the designer.
Blockquote15:43:48.607 [AWT-EventQueue-0] WARN Vision.Binding.SQLPropertyAdapter - Error running query:
SQLQuery(query=SELECT * FROM MBOM, database=SAPplm)@0ms
On: aaMBOM.Root Container.Table.data
at java.lang.Thread.run(Unknown Source)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:402)
at java.lang.Thread.run(null)
15:43:48.617 [AWT-EventQueue-0] ERROR Vision.Components.UserManagementPanel - Unable to describe user profile ""
java.util.concurrent.ExecutionException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing function 'Users.describeUserSource': The current user does not have the required roles for this operation.
at java.util.concurrent.FutureTask.report(Unknown Source)
at java.util.concurrent.FutureTask.get(Unknown Source)
at javax.swing.SwingWorker.get(Unknown Source)
at com.inductiveautomation.factorypmi.application.components.UserManagementPanel$DescribeUserProfileTask.done(UserManagementPanel.java:427)
at javax.swing.SwingWorker$5.run(Unknown Source)
at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
at sun.swing.AccumulativeRunnable.run(Unknown Source)
at javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing function 'Users.describeUserSource': The current user does not have the required roles for this operation.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:894)
at com.inductiveautomation.factorypmi.application.components.UserManagementPanel$DescribeUserProfileTask.doInBackground(UserManagementPanel.java:421)
at com.inductiveautomation.factorypmi.application.components.UserManagementPanel$DescribeUserProfileTask.doInBackground(UserManagementPanel.java:410)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
I have a user list on the screen with the table, and also I'm reading the current user, and it shows correctly. not sure why it does not seem to know who is the user.
I restarted the entire gateway and then opened the page again. It at least shows that my current login is valid and shows my roles. (user:mp).
BlockquoteCreating frame. extendedState=6, bounds=java.awt.Rectangle[x=0,y=0,width=2048,height=1152]
16:18:45.917 [Thread-6] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Updated login state. Logged in? true, Username: mp, Roles: [Admin, Kitting, MaterialDelivery, Operator, Planner, Quality, Receiving], Security Zones: null
16:18:46.031 [Thread-6] INFO ignition.TagManager.Gateway - Starting up polling tag manager, polling rate: 250 ms
16:18:46.589 [Thread-6] INFO com.inductiveautomation.reporting.client.ReportingClientHook - Starting up Reporting Module. Mode: Trial
16:18:46.642 [Thread-6] INFO com.sepasoft.production.client.ProductionClientModuleHook - ProductionClientModuleHook startup
16:18:46.661 [Thread-6] INFO com.sepasoft.trace.client.TraceClientModuleHook - Starting Recipe client module hook.
16:18:46.666 [Thread-6] INFO com.sepasoft.recipe.client.RecipeClientModuleHook - Starting Recipe client module hook.
16:18:46.667 [Thread-6] INFO com.sepasoft.quality.client.QualityClientModuleHook - Starting Quality client module hook.
16:18:46.667 [Thread-6] INFO com.sepasoft.oeedt2.client.OEEDT2ClientModuleHook - Starting OEE/DT V2 client module hook.
16:18:46.696 [Thread-6] INFO com.sepasoft.production.client.ProductionClientModuleHook - Initializing Client Production scripts.
16:18:47.279 [AWT-EventQueue-0] INFO vision.App - Starting Up...
16:18:54.467 [AWT-EventQueue-0] ERROR Vision.Components.UserManagementPanel - Unable to describe user profile ""
Dear PGriffith
Could you attach the picture for how to do by your solution.
Thanks,
