I recently installed ignition version 7.9.10.20181128-1303; I have Java version 8 update 181.
On clicking “Finish” after installation, an error popped up saying ignition.sh start exited abnormally.
On running ignition.sh start on the command line in /usr/local/ignition, I get the following:
Waiting for Ignition-Gateway…
WARNING: Ignition-Gateway may have failed to start.
Also here is the wrapper.log file contents:
STATUS | wrapper | 2019/02/08 10:29:17 | Launching a JVM…
ERROR | wrapper | 2019/02/08 10:29:17 | JVM exited while loading the application.
INFO | jvm 1 | 2019/02/08 10:29:17 | Unrecognized option: -d64
INFO | jvm 1 | 2019/02/08 10:29:17 | Error: Could not create the Java Virtual Machine.
INFO | jvm 1 | 2019/02/08 10:29:17 | Error: A fatal exception has occurred. Program will exit.
STATUS | wrapper | 2019/02/08 10:29:21 | Reloading Wrapper configuration…
STATUS | wrapper | 2019/02/08 10:29:21 | JVM process is gone.
STATUS | wrapper | 2019/02/08 10:29:22 | Launching a JVM…
ERROR | wrapper | 2019/02/08 10:29:22 | JVM exited while loading the application.
INFO | jvm 2 | 2019/02/08 10:29:22 | Unrecognized option: -d64
INFO | jvm 2 | 2019/02/08 10:29:22 | Error: Could not create the Java Virtual Machine.
INFO | jvm 2 | 2019/02/08 10:29:22 | Error: A fatal exception has occurred. Program will exit.
STATUS | wrapper | 2019/02/08 10:29:26 | Reloading Wrapper configuration…
STATUS | wrapper | 2019/02/08 10:29:26 | JVM process is gone.
STATUS | wrapper | 2019/02/08 10:29:26 | Launching a JVM…
ERROR | wrapper | 2019/02/08 10:29:26 | JVM exited while loading the application.
INFO | jvm 3 | 2019/02/08 10:29:26 | Unrecognized option: -d64
INFO | jvm 3 | 2019/02/08 10:29:26 | Error: Could not create the Java Virtual Machine.
INFO | jvm 3 | 2019/02/08 10:29:26 | Error: A fatal exception has occurred. Program will exit.
STATUS | wrapper | 2019/02/08 10:29:31 | Reloading Wrapper configuration…
STATUS | wrapper | 2019/02/08 10:29:31 | JVM process is gone.
STATUS | wrapper | 2019/02/08 10:29:31 | Launching a JVM…
ERROR | wrapper | 2019/02/08 10:29:31 | JVM exited while loading the application.
INFO | jvm 4 | 2019/02/08 10:29:31 | Unrecognized option: -d64
INFO | jvm 4 | 2019/02/08 10:29:31 | Error: Could not create the Java Virtual Machine.
INFO | jvm 4 | 2019/02/08 10:29:31 | Error: A fatal exception has occurred. Program will exit.
STATUS | wrapper | 2019/02/08 10:29:36 | Reloading Wrapper configuration…
STATUS | wrapper | 2019/02/08 10:29:36 | JVM process is gone.
STATUS | wrapper | 2019/02/08 10:29:36 | Launching a JVM…
ERROR | wrapper | 2019/02/08 10:29:36 | JVM exited while loading the application.
INFO | jvm 5 | 2019/02/08 10:29:36 | Unrecognized option: -d64
INFO | jvm 5 | 2019/02/08 10:29:36 | Error: Could not create the Java Virtual Machine.
INFO | jvm 5 | 2019/02/08 10:29:36 | Error: A fatal exception has occurred. Program will exit.
FATAL | wrapper | 2019/02/08 10:29:36 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2019/02/08 10:29:36 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2019/02/08 10:29:36 | <-- Wrapper Stopped
Any ideas? Thanks.
