Using Openpyxl 3rd party python library
Hello,
I’m trying to get openpyxl to work with Jython. I’ve followed steps from:
[Procedure for installing python libraries from source](http://Installing 3rd party python libraries)
and have used pip to install openpyxl using jython2.7.1. I can even see it in Ignition when I do help(“modules”). When I try to
import openpyxl
I get this error, even though I know that datetime functions work… there is a datetime.py in that cache folder… maybe that’s messing it up. Any luck with this?
thanks
File “”, line 2, in
File “C:\Users\controls.ignition\cache\gwlocalhost_8088\C0\pylib\openpyxl_init_.py”, line 6, in
from openpyxl.workbook import Workbook
File “C:\Users\controls.ignition\cache\gwlocalhost_8088\C0\pylib\openpyxl\workbook_init_.py”, line 4, in
from .workbook import Workbook
File “C:\Users\controls.ignition\cache\gwlocalhost_8088\C0\pylib\openpyxl\workbook\workbook.py”, line 7, in
from openpyxl.worksheet.worksheet import Worksheet
File “C:\Users\controls.ignition\cache\gwlocalhost_8088\C0\pylib\openpyxl\worksheet\worksheet.py”, line 24, in
from openpyxl.cell import Cell, MergedCell
File “C:\Users\controls.ignition\cache\gwlocalhost_8088\C0\pylib\openpyxl\cell_init_.py”, line 3, in
from .cell import Cell, WriteOnlyCell, MergedCell
File “C:\Users\controls.ignition\cache\gwlocalhost_8088\C0\pylib\openpyxl\cell\cell.py”, line 28, in
from openpyxl.utils.datetime import (
File “C:\Users\controls.ignition\cache\gwlocalhost_8088\C0\pylib\openpyxl\utils\datetime.py”, line 8, in
from datetime import timedelta, tzinfo
ImportError: cannot import name timedelta
Fairly certain it’s not vanilla python. Some of the inits import NUMPY and PANDAS which are CPython based. Unfortunately our Jython interpreter can’t handle Cpython libraries.
Latest version of openpyxl doesn’t support python 2.7. I downloaded the last version that supports it and am using it successfully - version 2.6.4. Only issue is that is uses SAX XML parser, which isn’t available in Vision, only in Designer. So, having to run scripts on Gateway instead of Client.
