Hi
I have a problem.
After a little time (1h), the vision client slows down. After 2h, the are very slow. The bug grows with time. If you restart the vision client, the vision client work correctly for one moment.
I am in vs 7.7.8. I am try vs 7.9.2 and it’s the same.
I am try to find the problem. I see client diagnostics and the memory rises and falls.
I am use ignition vs7.9 new functionality for try to find my problem.
In web server, status, Vision Clients, Client Details, in the Log Activity i am set “min level” to “trace” and i see lot of “ClientSubscriptionProxy.poll() start” and “ClientSubscriptionProxy.poll() - end (0ms”
I am test to rebuild the gateway from an empty project. After re-import the project and publish it, i have the same problem.
I certainly did a bullshit but that !!
Some one have an idea ? Do you have some tracks ?
Thank.
Maaxime.
