x = {}
isinstance(x,type(dict))
or
isinstance(x,dict)
x = {}
or
isinstance(x,dict)
The latter:
x = {}
print type(x)
print isinstance(x, dict)
print isinstance(x, type(dict))
Yields:
<type 'dict'>
True
False
That’s what I thought. The latter is correct when used in components and script console.
But from a project module, the first one works and the second does not.
In a project module:
isinstance(x,dict)
Yields:
TypeError: isinstance() arg 2 must be a class, type, or tuple of classes and types
Is there any chance you’ve accidentally used ‘dict’ as a variable name in that module? That would replace the built-in name.
It does not look like it. Should a call to locals() help identify this?
Yes, or just "print dict"
Hmm… Ok, removing line #2 fixed the issue.
print dict was returning a dictionary of all the modules in ‘project.states’.
Below function is used as a decorator.
from project.states import utility as states
#from project.states import *
def managementLock(func):
def fake(*args, **kwargs):
arg1,arg2='n/a','n/a'
if isinstance(args[0],dict): arg1,arg2=args[0]['Source'],args[0]['Target']
else: arg1,arg2=args[0],args[1]
project.activity.notify(project.activity.LOCK_IS_BOTTLENECK,[arg1,arg2])
return [False, "%s,%s locked by management" % (arg1,arg2)]
def inner(*args, **kwargs):
print locals()
print dict
if isLocked(arg1,arg2):
return fake(*args, **kwargs)
else:
return func(*args, **kwargs)
return inner
That would suggest that somewhere at the top level of project.states, something is assigning to dict.
In general, try to avoid from x.y.z import *
. You can break your code in unexpected ways.
I just searched my code base, and didn’t need to use import *
once.
Agreed, shame on me. Last year I ran into some other issue with import *. I forgot what problems it caused, but yeah.
Found my other import * issue…
http://forum.inductiveautomation.com/t/jython-import-behavior-in-custom-component-script/15688
Another reason to avoid it is that it doesn't work with java imports.
