Word wrapping column headers of the table object
How can I make the column headers of the table object multiple rows and force the text in the header to wrap?
thanks
travis
What you need to do is to use HTML to insert line breaks into the header text. For instance, <HTML>This will be<BR>two lines
The only trick to this is that the height of the entire table header row is determined by the height of the first header.
Hope this helps,
