XMLBeans Jar File Issue
I'm running into the same issue described in the linked post, and the solution described seems like it should work, but if I modify the file Maven decides it needs to re-download the file which just generates the issue again. Is there any tips or tricks to get around this? Nevermind maven doesn't re-download unless I remove things I'm not supposed to.
But I still am having issues having Ignition find this Class in order to execute my script.
  File "<buffer>", line 61, in <module>
  File "<buffer>", line 23, in getParseDataset
	at org.apache.poi.POIXMLDocumentPart.<clinit>(POIXMLDocumentPart.java:59)
	at org.apache.poi.ss.usermodel.WorkbookFactory.create(WorkbookFactory.java:86)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
java.lang.NoClassDefFoundError: java.lang.NoClassDefFoundError: org/apache/xmlbeans/XmlOptions
What issue are you having exactly? Do you have a custom module that includes poi and/or other jars?
As of now the module is just being built so that we can import the poi libraries to import excel files for a project. I managed to get version 4.0.1 to work, but poi is used for reporting module, and having the multiple versions seemed to cause some troubles.
I’m back to trying to use 3.14, but then it still is saying it can’t find the xmlbeans class even though the jar is included in the module.
Can you attach your module? And/or another error? The one you posted originally must be from attempting to use a newer version of poi.
That error should be from trying to use 3.14, but I am getting the following error after I switched from using poi-ooxml-schemas to ooxml-schemas as one post I read suggested. Haven’t looked into this one much yet though.
Jython 2.5.3 (v2.5.3:3d2dbae23c52+, Nov 17 2012, 11:51:23)
[Java HotSpot(TM) 64-Bit Server VM (Oracle Corporation)] on java1.8.0_201
Java Traceback:
	at org.python.core.Py.JavaError(Py.java:495)
	at org.python.core.Py.JavaError(Py.java:488)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
	at org.python.core.PyObject.__call__(PyObject.java:387)
	at org.python.core.PyObject.__call__(PyObject.java:391)
	at org.python.pycode._pyx4.getParseDataset$2(<buffer>:41)
	at org.python.pycode._pyx4.call_function(<buffer>)
	at org.python.core.PyTableCode.call(PyTableCode.java:165)
	at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
	at org.python.core.PyFunction.function___call__(PyFunction.java:376)
	at org.python.core.PyFunction.__call__(PyFunction.java:371)
	at org.python.core.PyFunction.__call__(PyFunction.java:361)
	at org.python.pycode._pyx4.f$0(<buffer>:43)
	at org.python.core.Py.runCode(Py.java:1275)
	at org.python.core.Py.exec(Py.java:1319)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:215)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:89)
	at org.python.util.InteractiveInterpreter.runsource(InteractiveInterpreter.java:70)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:476)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:464)
	at javax.swing.SwingWorker$1.call(Unknown Source)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at javax.swing.SwingWorker.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Caused by: org.apache.poi.POIXMLException: java.lang.reflect.InvocationTargetException
	at org.apache.poi.POIXMLFactory.createDocumentPart(POIXMLFactory.java:65)
	at org.apache.poi.POIXMLDocumentPart.read(POIXMLDocumentPart.java:601)
	at org.apache.poi.POIXMLDocument.load(POIXMLDocument.java:174)
	at org.apache.poi.xssf.usermodel.XSSFWorkbook.<init>(XSSFWorkbook.java:249)
	at org.apache.poi.ss.usermodel.WorkbookFactory.create(WorkbookFactory.java:211)
	at org.apache.poi.ss.usermodel.WorkbookFactory.create(WorkbookFactory.java:170)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
	... 27 more
Caused by: java.lang.reflect.InvocationTargetException
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
	at java.lang.reflect.Constructor.newInstance(Unknown Source)
	at org.apache.poi.xssf.usermodel.XSSFFactory.createDocumentPart(XSSFFactory.java:56)
	at org.apache.poi.POIXMLFactory.createDocumentPart(POIXMLFactory.java:62)
	... 37 more
Caused by: java.lang.NoSuchMethodError: org.apache.xmlbeans.XmlOptions.setLoadEntityBytesLimit(I)Lorg/apache/xmlbeans/XmlOptions;
	at org.apache.poi.POIXMLTypeLoader.<clinit>(POIXMLTypeLoader.java:50)
	at org.apache.poi.xssf.model.ThemesTable.<init>(ThemesTable.java:85)
	... 43 more
org.apache.poi.POIXMLException: org.apache.poi.POIXMLException: java.lang.reflect.InvocationTargetException
It seems like all the other libraries your’e trying to use are depending on a newer version of POI than you have available to you.
For example, POIXMLDocumentPart doesn’t exist in poi 3.14.
As for the module, its too big to upload, but here are the main parts.
module.xml (1.4 KB)
This stuff is hard to troubleshoot. Nothing looks wrong with your module contents, but I couldn’t say for sure if everything that’s supposed to be there is actually there, and if all your dependencies are present and sane.
You might be able to use mavens dependency plugin to analyze what your dependencies are and compare them to what’s in the module. Use mvn dependency:list or mvn dependency:analyze.
Also just sanity check and look for the class that’s supposedly missing among the jar files being included.
Thanks for the pointers at least. Wasn’t sure if I was missing something blatantly obvious since I’m finding my way around Maven and some of these libraries a bit.
I think that last issue was because I had poi-ooxml-schemas and ooxml-schemas. I switched back to just poi-ooxml-schemas, followed by a clean and invalidate caches and it looks like I’m up and running.
