EA-Weekly Changelog: 8.3.0*-b20250124
Tag Historian
Tag Historian
IGN-11866: Web UI: Historians Page is Inaccessible
Fixed issue where the Historian web page was inaccessible due to the incorrect path used for serving the bundled js file.
EA-Weekly Changelog: 8.3.0*-b20250127
IGN-11474: Fix NPE on Twilio SMS Notification profiles and fix Sonar issue with stream pipelines in Twilio and Sms Notification Profiles
Fixed an issue where the Twilio SMS notifications weren't sent out due to NPE caused from its ackManager not being initialized properly
IGN-10205: RFC-32 (Modern RPC) Adoption: Vision
Updated the Vision module to use the new RPC standard interfaces as well as take advantage of new config APIs for the local fallback cache user source type.
EA-Weekly Changelog: 8.3.0*-b20250128
IGN-11510: Handle module identifier change for SQL Historian in Docker
Fixed an issue where use of GATEWAY_MODULES_ENABLED legacy identifier tag-historian would not properly enable both Historian modules on an upgrade of a Docker environment.
IGN-10193: RFC-32 (Modern RPC) Adoption: OPCUA
Implemented Modern RPC for system.opc methods.
EA-Weekly Changelog: 8.3.0*-b20250131
IGN-10827: 8.3 Gateway: Remove advanced button from edit drawers
Standardizes forms to more consistently follow their intended behavior such that advanced options are always shown during edit, but hidden by default (with a toggle button) during creation of a new resource.
^^^ Pay no mind to this duplicate. ^^^
Had to re-run the pipeline.
EA-Weekly Changelog: 8.3.0*-b20250203
IGN-11070: Add password support for root key unsealing strategy (secrets manager)
The root key protecting the custom secrets management key set is now password-protected
IGN-10002: RFC-68 Adoption: Quick Start
Quickstart now uses native resource collections.
IGN-11164: 8.3 Gateway Navigation: Nav restructure (settings, tags, historians)
Restructured the Web UI navigation menu based on latest feedback
EA-Weekly Changelog: 8.3.0*-b20250204
IGN-11346: Store & Forward: Fix improper batching when retrieving serialized data from local SQLiteStore
Fixed S&F batching query to use point count instead of row counts
IGN-11840: Perspective Brand Settings configuration should be split into categories
Re-organized the Perspective Brand Settings page according to latest designs
IGN-11388: 8.3 Gateway: Edge Edition Interfaces
The Sync Settings and Sync Reset pages have been moved to an Ignition Edge category, which will only be displayed on Edge gateways.
EA-Weekly Changelog: 8.3.0*-b20250205
IGN-11511: Prevent Apple x86 Ignition upgrade zip from being sent to 8.3 agents
Fixed issue allowing EAM Remote Upgrade task to send older version than currently installed to Agents.
EA-Weekly Changelog: 8.3.0*-b20250210
IGN-11953: system.user.editUser permits duplicate usernames in Internal and Database User Sources
Fixed issue where both roles and users could be created with duplicate names from the script console for internal and database user sources.
IGN-10574: 8.3 Gateway File Upload component has no disabled state change
Adds missing disabled state to the FileUploader component
EA-Weekly Changelog: 8.3.0*-b20250211
IGN-11692: Bump Ignition Cloud Edition 8.3 base to Ubuntu 24.04 LTS
Ignition Cloud Edition version 8.3.0 is now based on Ubuntu Server 24.04 LTS.
IGN-10892: 8.3 Database Connections page: ResourceModeDataGrid refactor and fixes
Overhauled the Database Connections page to use the latest frontend components and fixed several bugs on that page
Known issues:
EA-Weekly Changelog: 8.3.0*-b20250212
IGN-10986: 8.3 Gateway Pages: Integrate Alarm Settings
Home
Designer > Download
Designer > Connections
Perspective > Launch
Perspective > Download
Vision > Launch
Vision > Download
Database Connections page now supports deployment modes and backup configuration
Fixed status badge to properly reflect database connection errors
Fixed unable to rename database connections
Fixed changes to description field do not persist
Fixed actions menu is hidden when overflowing outside parent container
Fixed page error when attempting to copy a stack trace
Fixed stack trace modal closes when polling
Fixed missing "none" option in failover select
Improved stack trace formatting
Added missing metric card
Known issues:
EA-Weekly Changelog: 8.3.0*-b20250213
EA-Weekly Changelog: 8.3.0*-b20250224
IGN-10707: Event Streams: Database Handler UI update
IGN-11910: SFC Settings page Deployment Mode and config overhaul
SFC Settings page now supports deployment and config modes
EA-Weekly Changelog: 8.3.0*-b20250225
IGN-12103: 8.3: Remove RecordEditForm from Component Library
Removed the outdated RecordEditForm from the Web UI component library
IGN-11591: Twilio Voice Notification Followup - sendPhoneCall Scripting & Serial Calls Functionality, Config Defaults, Auditing
Add answerTimeout and maxCallDuration fields to Twilio Voice Notification Profiles; Add getActiveCalls scripting function.
IGN-11984: CSRF vulnerability reported in 2024 Bug Bounty (Create a Project)
Fixed minor security issues
EA-Weekly Changelog: 8.3.0*-b20250227
IGN-11557: Forward port: Alarm is stuck inside pipeline after meeting a disabled dropout condition
Refactored BasicAlarmEvent to return appropriate alarm data based on last alarm event's state and alarms from getting stuck in alarm pipelines.
IGN-11927: Perspective Cobranding Settings Deployment Mode and config overhaul
RecordEditForm from the Web UI component libraryIGN-11984: CSRF vulnerability reported in 2024 Bug Bounty (Create a Project)
EA-Weekly Changelog: 8.3.0*-b20250228
IGN-11904: Audit Logs Deployment Mode and config overhaul
Audit Profiles page now supports deployment modes and backup config.
Due to changes in the form handling, audit profiles created in previous versions may see a validation error saying "Description cannot be null" when attempting to edit an audit profile with no description. Workaround: provide a description when editing, save changes, then remove the description again if needed.
IGN-10202: RFC-32 (Modern RPC) Adoption: Reporting
Transitioned the existing RPC over to the Modern RPC.
