A tag average over time
What rate is the history being collected on Water Age Days? The script works in the script console and there is no reason it should not work in the gateway timer. Something seems amiss with the data, the only explanation is system.tag.queryTagHistory() is returning a blank dataset.
Unless there is something else writing to the tag which I find hard to believe if you created a new tag.
Go into your logs when the gateway script is running and check for errors
Like the actual gateway console logs?
You are still missing the tag provider here. Format your code when you paste it in the forum, so it can be read easier.
now = system.date.now()
startDate = system.date.addHours(now, -1)
endDate = now
avg = system.tag.queryTagHistory(paths=["[default]East Res/Water Age Days"], startDate=startDate, endDate=endDate, returnSize=1, aggregationMode="SimpleAverage")
system.tag.write("[default]East Res/Water Age Ave",avg.getValueAt (0,1))
Headbashes the desk
Forgive me, we have just been all over the loop with this code that I didn’t even see that.
And wouldn’t you know it
It finally
Freaking
Works!
Every six seconds (right now) if the average changes the tag number changes.
It’s been 3 minutes and so far it has not broken
Thank you all so so much.
I see you have it working but for future reference, yes, any errors from gateway scripts go to the gateway log files in the status section of the gateway
Ok I thought that’s what you were referencing but I wasn’t…100% sure.
