About Ignition 2027 Early Access
Subscribed! Our team builds DCIM, BMS, and EPMS systems for data centers in Korea, so we’re really looking forward to what 2027 brings. We’d love to see continued improvements in Gateway Redundancy and failover behavior, as well as broader support for power-system protocols like IEC 61850. Happy to test the beta and share feedback from the field!
In general, it's not a concern.
The key point is that we are not running the actual LLM inference, nor are your gateways. They are calling out to whatever provider you choose to connect to - most likely, one in a remote cloud (though self-hosted options are available, in which case providing the model and the hardware to run it becomes your responsibility).
The gateway diagnostic assistants are carefully bound to minimize impact on the active runtime while they're collecting diagnostics - this is pretty much the only area where we've seen resource usage that could be a problem at scale, but you're more than welcome to turn off the diagnostic assistants on your production systems and still enjoy the other benefits of the Catalyst modules.
Great! I'm really excited about this update.
Will Ignition2027 client launchers be backward compatible or configurable to be backward compatible to 8.3.x and/or 8.1.x?
I asked that question at ICC. They told me 8.3 yes 8.1 not sure.
Catalyst looks like a game chagner for us, we have a small team and Perspective development can sometimes be difficult.
I only had about ten minutes to try the beta, but I couldn't get Catalyst to connect properly to LMStudio's OpenAI compatible endpoint for my locally running models. (I have a RTX 5090 so figured why not use it to avoid paying for tokens while I am getting my bearings.) It failed completely without an API key even with LMStudio set to not require one. When I did create an API key, it failed at parsing what was returned from the /v1/models endpoint. I'll get Ollama set up later and see if I have any better luck.
You might also want to take a look at ~/.ignition/catalyst/README.md, which has some instructions on how to set up a designer local model provider connection.
EDIT: Corrected path; my local environment was out of date.
Works well for me with Claude and Ollama with multiple models. On my MacBook Pro M4 48gb, lets say that it's not usable. Claude (didn't try OpenAI or other yet), is fast.
One thing to note, I had to relaunch my Designer after adding a new model.
yes, YMMV on local models and their performance
Thanks, I'll take a look in depth when I have time later today but the path to that file for me was ~/.ignition/catalyst/README.md
Update: Manually editing the connection allowed it to work, but still no dice when trying to set it up through the gateway web UI. Qwen3.8 27B w/ MTP actually did a pretty decent job with what I was playing around with.
Thought I'd drop in what I worked out to get this to work for LMStudio without an API key while going through the webGUI for the gateway. Basically the 'None' option for the API key breaks the configuration for OpenAI compatible endpoints. Even if the endpoint doesn't require an API key you still need to enter in something through the embedded or referenced options.
Whatever configuration error happened when 'None' is selected persisted through edits and gateway restarts, I had to delete the original configurations and start from scratch using a placeholder value for the API key for it to work properly.
Obviously in an actual production environment you're going to want to have an API key even if the software defaults to not requiring one, even on a local system, but LMStudio is common enough that I wouldn't be surprised if this 'issue' comes up more than a few times.
Model Provider is setup and working, I can see troubleshooting on Diagnostics>Session, but the option is not there for Logs, is that missing feature on first beta version? also I can use ASK AI on designer for Database Query or scripting, but the view ASK AI feature for biding and overall designer component creation by AI is not there, is that intended? is there any overall designer ASK AI feature?
See my post here:
Just gave it a spin and noted my first thoughts! In case you might be interested:
