Advice requested: Advice: Best way to integrate PTZ ONVIF camera into Ignition 8.3 (Vision)
Hi everyone
I’m integrating PTZ cameras into an Ignition 8.3 (Vision) system and I need advice which development approach to choose.
  • PTZ control (move, goto preset)
  • snapshot capture (later stored in MongoDB)
  • scheduled timelapse (camera moves to preset → capture → back)
I tried calling the camera’s ONVIF endpoints directly from Ignition using system.net.httpGet / httpPost, but I always get 401 Unauthorized. ONVIF requires WS-Security (UsernameToken, PasswordDigest), which is hard to implement in Ignition’s Jython scripting.
So I see two possible approaches:
Option A — Direct in Ignition (Jython/SOAP):
  • Build WS-Security SOAP requests in scripts, post them to the camera.
  • Pros: single environment, simpler deployment.
  • Cons: implementing WS-Security and parsing SOAP in Jython is difficult, harder to maintain.
    :backhand_index_pointing_right: If you recommend this, could you share a tested Jython example for PTZ (e.g., GotoPreset with UsernameToken)?
Option B — External Python middleware (Flask + ONVIF library):
  • Middleware handles ONVIF via a proper library, exposes simple REST endpoints for Ignition.
  • Pros: easier to develop & maintain, good for future MongoDB/timelapse features.
  • Cons: adds another service to deploy.
    :backhand_index_pointing_right: If you recommend this, any example Flask + ONVIF snippets or best practices for connecting Ignition to it?
Question: For a project that will later need MongoDB snapshot/timelapse storage, which approach do you recommend for long-term development?
Thanks in advance for any advice or code samples!
