Alarm tags - bits
[quote=“JordanCClark”]OK, let me see if I have this right… It’s because I’m not a Siemens guy. :laughing:
You can export from the Siemens software directly as an Excel file? If so, are there any other formats available? I ask this so that we can perhaps skip a step.[/quote]
No. Siemens software support .asc (ASCII), .seq (for older Simatic systems) and .dif (Data Interchange Format). DIF file is the one, which can be normally open in Excel, manipulated and then saved as csv.
ASC file is normal text file (you can edit it in Notepad), but it’ll need some processing before converting it to Ignition xml.
I attached .csv and .asc (remove .zip) file and Ignition tags export/import .xml file, and .dif file (remove .zip) which can be opened in Excel and manipulated.
I opened .dif in Excel, change the columns (M 100.0 -> MX100.0, M 100.0 -> M100_0) and save it as .csv.
In .csv:
First column (MX100.0) is tag format for Ignition. Bit tags in Ignition have X.
Second column (M100_0) is tag name for Ignition (Hence _, because Ignition won’t allow dots in tag names).
Third column is tag type; BOOL in Siemens is DataType 6 in Ignition
Fourth column is Alarm text in Siemens, and Alarm name in Ignition.
Thats not exactly true. I'm also using Calc to create tags from external sources. I usually create a template tag in Ignition, export as XML and then use Calc with some cell formulas and copy/paste or autofill to create additional tags. Then i reimport the new tags into Ignition. That's also the reason for the seperate alarms table, you can simply copy/paste your alarm texts there.
That's maybe a bit more work than you want to do, but it works perfectly for me and my co-worker which know how to use Excel/Calc but not how to write scripts in Ignition.
I attached a sample table to this post (Just delete the '.zip' from the filename, the forum software does not accept .ods files).[/quote]
Yes, I understand. I tried your filters in OpenOffice and I might use that.
But, I see in your latest attachment that you have defined MW as tags, and then in alarms sheet you used bitPosition (0-15).
How is that?
[quote]But, I see in your latest attachment that you have defined MW as tags, and then in alarms sheet you used bitPosition (0-15).
How is that?[/quote]
I find it easier to use a word tag and define 16 alarms for the single bits. If i remember right, this option is new in 7.6.
[quote=“zxcslo”]
In .csv:
Fourth column is Alarm text in Siemens, and Alarm name in Ignition.[/quote]
Wow! My cup runneth over! Thanks!
One more question. I see in your SQLTag file that you have an Alarm setpoint of 10. Is that deliberate? Booleans, as you know, won’t get there. I can stick it in as a 10, I just wanted to be sure that’s what you wanted. :slight_smile:
[quote=“JordanCClark”][quote=“zxcslo”]
In .csv:
One more question. I see in your SQLTag file that you have an Alarm setpoint of 10. Is that deliberate? Booleans, as you know, won’t get there. I can stick it in as a 10, I just wanted to be sure that’s what you wanted. :slight_smile:[/quote]
No, I think that’s the bug in Ignition tag export/import routine:
I’m from Europe (Slovenia) and we have a comma (,) for decimal separator and dot (.) for thousands. (set in Windows Regional settings)
When you do tag export, there is always 1.0 (instead of 1,0) in xml file. When you do import the same file, you get 10. If the change is made by hand in xml file from 1.0 to 1,0 it’ll import correctly.
So I guess export doesn’t care about regional settings, but import does.
I just give you this file without corrections. There must be Alarm setpoint at 1.0 (1,0).
[quote=“chi”][quote]But, I see in your latest attachment that you have defined MW as tags, and then in alarms sheet you used bitPosition (0-15).
I find it easier to use a word tag and define 16 alarms for the single bits. If i remember right, this option is new in 7.6.[/quote]
Wau… I didn’t know that… :blush:
I’ve looked again and now I found it.
The last project I have, I made it with v7.6.6 and I didn’t know about this, so I defined all alarms tags as BOOLEAN… :slight_smile:
Oh well…
Here’s the first crack at making an XML file from a Siemens .asc file. Should be locale agnostic, meaning it should pop in the correct decimal point for your locale. At least, that was the plan! :mrgreen:
[code]import xml.etree.ElementTree as ET
import locale
decimalPoint=locale.localeconv()[‘decimal_point’]
thousandsSep=locale.localeconv()[‘thousands_sep’]
OPCServer=‘Ignition OPC-UA Server’
deviceName=’[s7_300]’
alarmFolderName=‘Napake’
pathIn=system.file.openFile(‘asc’)
if pathIn != None:
txt = system.gui.inputBox(“OPC Server:”, OPCServer)
if txt != None:
OPCServer=txt
txt = system.gui.inputBox(“Device Name:”, deviceName)
if txt != None:
deviceName=txt
txt = system.gui.inputBox(“Alarm Folder Name:”, alarmFolderName)
if txt != None:
alarmFolderName=txt
fileIn=open(pathIn)
#Root
writeTree=ET.Element('Tags')
#Alarm Folder
alarmFolder=ET.SubElement(writeTree, 'Tag', {'name':alarmFolderName, 'path':'', 'type':'Folder'})
for line in fileIn:
    bit=line[line.find(',')+1:25].strip().replace(' ','X')
    tagname=bit.replace('X','').replace('.','_')
    desc=line[50:].strip()+' ('+bit.replace('X','')+')'
    tag=ET.SubElement(writeTree, 'Tag', {'name':tagname, 'path':alarmFolderName, 'type':'OPC'})
    property=ET.SubElement(tag, 'Property', {'name':'Value'})
    property.text='false'
    property=ET.SubElement(tag, 'Property', {'name':'DataType'})
    property.text='6'
    property=ET.SubElement(tag, 'Property', {'name':'OPCServer'})
    property.text=OPCServer
    property=ET.SubElement(tag, 'Property', {'name':'OPCItemPath'})
    property.text=deviceName+bit
    #Set up alarm properties
    alarms=ET.SubElement(tag, 'Alarms')
    alarm=ET.SubElement(alarms, 'Alarm',{'name':desc})
    property=ET.SubElement(alarm, 'Property', {'name':'priority'})
    property.text='1'
    property=ET.SubElement(alarm, 'Property', {'name':'setpointA'})
    property.text='1'+decimalPoint+'0'
    property=ET.SubElement(alarm, 'Property', {'name':'ackMode'})
    property.text='1'
fileIn.close()
path = system.file.saveFile(deviceName.replace('[','').replace(']','')+".xml")
if path != None:
    rough_string = ET.tostring(writeTree, 'utf-8')
    system.file.writeFile(path,rough_string)
[/code]
Here’s one that may use bit position alarms. I say may, because some of the Unicode characters seem to get hosed going into and out of the dictionaries. It may be a locale thing, so your mileage may vary… hopefully better than mine! :unamused:
Really, I’m not in the habit of handing out stuff that doesn’t work, but it will work with ASCII. It’s Unicode manipulation that seems to be my current nemesis. :laughing:
import locale
locale.setlocale(locale.LC_ALL, ‘sl-si’)
if pathIn != None:
if txt != None:
OPCServer=txt
if txt != None:
deviceName=txt
if txt != None:
alarmFolderName=txt
fileIn=open(pathIn)
AlarmDict={}
for line in fileIn:
    ElementDict={}
    word=bit[:bit.find('.')].replace('X','W')
    if word not in AlarmDict:
        AlarmDict[word]={}
    if bit not in AlarmDict[word]:
        AlarmDict[word][bit]=[tagname, desc]
fileIn.close()
#Root
#Alarm Folder
for wordKey in AlarmDict.keys():
    tag=ET.SubElement(writeTree, 'Tag', {'name':wordKey, 'path':alarmFolderName, 'type':'OPC'})
    property.text='1'
    for bitKey in AlarmDict[wordKey].keys():
        bitPosition=bitKey[bitKey.find('.')+1:]
        desc=AlarmDict[word][bit][1]
        print desc
        alarm=ET.SubElement(alarms, 'Alarm',{'name': desc})
        property.text='1'
        property.text='1'
        property=ET.SubElement(alarm, 'Property', {'name':'bitPosition'})
        property.text=bitPosition
if path != None:
    system.file.writeFile(path,rough_string)[/code]
@JordanCClark
Thank you for your effort. :prayer:
Let’s talk about your first script:
When I run it, I get the xml file. When I try to import that xml file, I get error:
[attachment=2]Capture2.PNG[/attachment]
The other thing is about locale decimal point and thousand separator:
I’ve put in the script:
import locale
print “Decimal point :” + decimalPoint
print "Thousand sep: " + thousandsSep
#print locale.getdefaultlocale()
print locale.localeconv()
[/code]
And this is what I get in output console:
[attachment=1]Capture3.PNG[/attachment]
In Regional settings in Windows decimal point is set to comma (,) and thousand separator to dot (.).
I guess the locale function behave differently on Windows OS than on Linux or else… :slight_smile:
Next thing:
When I add locale.setlocale(locale.LC_ALL, ‘sl-si’):
import locale
#print locale.localeconv()
alarmFolderName=‘Napake2’
pathIn=system.file.openFile(‘asc’)[/code]
I get this error:
[attachment=0]Capture4.PNG[/attachment]
EDIT:
The first error (invalid byte…) is gone if I remove utf-8 from ET.tostring:
if path != None: #rough_string = ET.tostring(writeTree, 'utf-8') rough_string = ET.tostring(writeTree) #print rough_string system.file.writeFile(path,rough_string)
Now I can import xml file and I get all the tags, but some slovenian characters are not right.
I guess it has something to do with encoding of the asc file and/or the Ignition/Java.
In slovenian language we have a few special characters, like čćžšđ ČĆŽĐŠ, and no mater what I try, I can’t get this characters into xml file…
I have encoded .asc file to utf-8, unicode, ansi (default),… but nothing…
EDIT EDIT:
I’ve tried all this in v7.7.0-beta3 (b2014061610).
It’s the same… the only thing that’s different is that now, when you import tag xml and setpointA is 1,0 (with comma), you’ll get 10 in Ignition Tag Editor. So it must be 1.0 (with dot). It reverse from v7.6. Now it doesn’t care at all, what is local decimal separator set in Windows Regional settings.
Thanks for the update. Oddly enough, that first script worked ok for me, special characters and all. :open_mouth:
Yeah, those special characters are giving me fits! And trying to set a locale is not much better. I’ll take a closer look at Java’s classes. Maybe there something in there that will work better for locales. :imp:
If you still have trouble with the decimals and thousands separator, you can hard code the values. In my case it would look like:
EDIT: removed bad code... really bad code... See later post.
On the bright side, we have a basic framework that does what it’s supposed to do. Now, if we can get rid of the ‘undocumented features’, we’ll have something special!
To the general public: I don’t think zxcslo or my feelings will get hurt if someone else jumps in. There’s plenty of room in the pool, and the water’s nice! :smiley: I’ve got about one more day I can put toward this before vacation. After that, it’ll be about a week.
When I put:
decimalPoint=locale.localeconv()['.'] thousandsSep=locale.localeconv()[',']
I get this: :scratch:
[attachment=0]Capture1.PNG[/attachment]
Sorry. It was early when I wrote that. :blush:
decimalPoint='.' thousandsSep=','
After a long time, I return to this ‘problem’, because now I was really need to import over 3000 tags from Siemens Simatic PLC to Ignition.
With the help of others, participating in this thread :prayer: I find 3 ways to do it:
  1. This is the longest way (much hand work involved and I wrote a small program in VS2010, because I’m more of Microsoft guy for most of my life :blush: )
  2. Second way will convert exported ascii txt (.asc) file from Simatic Manager to Ignition XML, with the help of Python (Jyton) script from inside the Ignition designer (Script playground), to Bit (Boolean) Tags with alarms defined for each tag
  3. Third way will convert exported ascii txt file (.asc) from Simatic Manager to Ignition XML, with the help of Python (Jyton) script from inside the Ignition designer (Script playground), to Byte Tags with alarms defined for each bit in that Byte tags.
I’ve attached all three files (one .zip and two txt files).
Feel free to look, try, adapt and please, comment on them. :thumb_left:
STEP7 alarm taqs to Ignition ByteTags 3way.txt (4.29 KB)
STEP7 alarm taqs to Ignition BitTags 2way.txt (3.44 KB)
STEP7 alarm taqs to Ignition_1way.zip (131 KB)
After a year and few new versions of Ignition, I still have problem with our Slovenian (or Russian) language in Ignition, regarding alarm texts.
I’m using script from @JordanCClark to create XML tags file from my utf8 encoded .csv file, which contains slovenian (and russian, for test) texts for alarms.
The script runs fine; all my alarm tags are created fine, with alarms texts for each bit in each byte…
But… the problem are our slovenian (and russian) ‘special’ characters (šđčćž)…
In the output window of script console in Ignition designer, all texts are correct (with slovenian characters). But in generated XML file, opened in Notepad++, there are NO slovenian (or russian) characters. And XML, according to Notepad++, is not UTF8 encoded…
I’ve read this thread wit interest.
But when I try to download the scripts from the link in your post, I get an error message:
" Oops! That page doesn’t exist or is private."
Do the scripts still exist ?
Or is there a better way now 4 years later of mass importing Siemens tags ?
The forum was upgraded from then and many files/links were lost…
No, there still isn’t a better way to mass import tags from Siemens.
Now, with TIA it’s a little easier to import the tags and symbolic to Excel (copy and paste).
What I’m doing now is copy and paste the entire tag table from TIA to Excel, edit/delete the columns I don’t need and save as UTF8 .csv file.
Then, depending on what kind of tags I’m importing, I usually use the script from the last project and change it to current needs. There is no universal script for every need (or at least I’m too lazy to write one), so every time I need to mass import I’m using and changing the script from the last project…
Here is an .zip file with some of my scripts:
STEP7 alarm taqs to Ignition.zip (286.3 KB)
thanks for that.
Any suggestions on how to handle where my alarm bits are in a DB ?
I’m struggling to work out how to export the symbols from a DB definition (step7 ‘traditional’).
cheers,
The only way that I know is to select all rows in the DB, copy them to clipboard and paste into the Excel.
Then you must edit/format the values in the columns to your liking and then save that as UTF-8 .csv.
We needed to bring in tags from TIA and found a third party OPCUA server that makes it possible to browse for all of the Siemens tags in a sufficient format. Its called TANI OPCUA Server. We tried kepwares OPCUA server and did not like how the files were brought in. At this point with TANI we have over 500,000 tags with a licence for 1000,000 tags, there are smaller packages.
