Ok. You don’t need a local address at all if Ignition itself will be the only connection. If it still shows N/A, check the logs for anything suspicious. (Filter for com.automation_pros.enip1)
Looks like you’ve installed the wrong version of my module. See the list here:
https://www.automation-pros.com/modulesales.html
What version of Ignition are you using?
8.1.1
I thought we were still on 8.0.
I download the correct one and it fixed the problem thanks.
