It turns out that this was just a symptom of the using the Designer environment to test this. The Initial Read does trigger the event, but the window that the component to be gradient filled is on must be CLOSED in the designer. So because I had it open in the designer, and was using the preview mode, it was never updating when going from "Stop" to "Play." In the actual run-time, this is not an issue.
