I am trying to open an ignition client that is connected to the network. When I try to launch the vision client with auto login, I get a pop up with the following.
ArrayIndexOutOfBoundsException: Index 0 out of bounds for length 0.
Unfortunately, you haven’t give enough context to the error message for us to really be able to help. There should be more detail than this with the error message, that will tell where it occurred.
At the very least a screen snip of the error dialog box would help.
I just encountered the same error on recovery from a power outage. This was on a project set to auto-login as mentioned in @Ignition_Newbie’s first post above.
Error details
java.lang.ArrayIndexOutOfBoundsException: Index 0 out of bounds for length 0
at org.python.objectweb.asm.ClassReader.readStringish(ClassReader.java:3493)
at org.python.objectweb.asm.ClassReader.readClass(ClassReader.java:3508)
at org.python.objectweb.asm.ClassReader.accept(ClassReader.java:430)
at org.python.objectweb.asm.ClassReader.accept(ClassReader.java:400)
at org.python.core.AnnotationReader.<init>(AnnotationReader.java:47)
at org.python.core.imp.readCodeData(imp.java:387)
at org.python.core.imp.createFromPyClass(imp.java:284)
at org.python.core.imp.createFromPyClass(imp.java:255)
at org.python.core.imp.loadFromSource(imp.java:929)
at org.python.core.imp.find_module(imp.java:769)
at org.python.core.imp.import_next(imp.java:1158)
at org.python.core.imp.import_first(imp.java:1198)
at org.python.core.imp.load(imp.java:1016)
at org.python.core.PySystemState.initializeCodecState(PySystemState.java:374)
at org.python.core.PySystemState.getCodecState(PySystemState.java:360)
at org.python.core.codecs.setDefaultEncoding(codecs.java:42)
at org.python.core.PySystemState.setdefaultencoding(PySystemState.java:536)
at com.inductiveautomation.ignition.common.script.ScriptManager.createUtf8PySystemState(ScriptManager.java:257)
at com.inductiveautomation.ignition.common.script.ScriptManager.<init>(ScriptManager.java:134)
at com.inductiveautomation.ignition.common.script.ScriptManager.<init>(ScriptManager.java:113)
at com.inductiveautomation.factorypmi.application.runtime.ClientContextImpl.startup(ClientContextImpl.java:359)
at com.inductiveautomation.factorypmi.application.runtime.ClientPanel.startupApp(ClientPanel.java:846)
at com.inductiveautomation.factorypmi.application.runtime.ClientPanel.onProjectDownloadFinished(ClientPanel.java:820)
at com.inductiveautomation.factorypmi.application.runtime.DownloadProjectPane.lambda$new$0(DownloadProjectPane.java:72)
at java.base/java.util.concurrent.CompletableFuture.uniWhenComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.complete(Unknown Source)
at com.inductiveautomation.factorypmi.application.runtime.DownloadProjectPane$DownloadProject.run(DownloadProjectPane.java:111)
at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33)
Ignition v8.1.18 (b2022061518)
Java: Azul Systems, Inc. 11.0.15```
Restarting the gateway resolved the issue and clients connected as usual.
