Automation Professionals' Blob Server Module
After you switch back to varbinary, make sure whatever inserts into the table pushes bytes, not a string.
This is what was used to populate the table...
INSERT INTO [dbo].[FILLER_HELP_FILES_TEST]
           ([file_id]
           ,[file_blob])
		SELECT 'Check Scale.pdf'
           ,BulkColumn
		FROM
			OPENROWSET(BULK 'C:\Projects\CRI\Fillers\CLX\Ignition\HelpFiles-Filler\Check Scale.pdf', SINGLE_BLOB)
		AS BLOB;
I have no idea how that SQL Server-specific function works, sorry.
A script like this in the designer would be typical:
blob = system.file.readFileAsBytes("path/to/some/someName.pdf")
fname = "someName.pdf"
sql = """INSERT INTO some_table (file_id, file_blob) VALUES (?, ?)"""
print system.db.runPrepUpdate(sql, [fname, blob])
Should print 1 for the DB return value.
The NQ SQL should be just:
SELECT 'application/pdf' AS "ContentType", file_blob AS "Content"
WHERE file_id = :file_id
Varbinary column type made the content results in the NQ tester look a bit different, but still no joy in the browser.
I'll give your script a shot.
Except that it needs the table name :slightly_smiling_face:
SELECT file_blob as "Content", 'application/pdf' as "ContentType"
FROM FILLER_HELP_FILES_TEST
I just remembered:
Make sure there's a unique index on file_id, since you aren't looking up by primary key. If the NQ yields more than one row, you get nothing.
Thank you.
As an update, using system.file.readFileAsBytes() and system.db.runPrepUpdate() solved the problem. Apparently the sql server OPENROWSET() function, at least in the way that I used it, does not load the data in a manner that your module expects.
Thanks so much for your module and support!
How can I 'clean-up' all the resources (URL) that module has created?
Thank you.
Delete the rows from your database. This module doesn't create any content. It just presents what you have in your DB. You put content there. You have to take it out.
Thank you very much, I didn't notice that.
@pturmel I really love this module, really appreciate for inventing and sharing this. Really helps to access images, and pdf from database, by feeding required format url to a Image or iFrame component.
Important question.. If I am not using this module, how will I access images and pdf and feed it to an Image or Iframe component?
Use the WebDev module to run the NQs instead.
Is this module still available? Thanks!
The download link is in post #75 above, Automation Professionals' Blob Server Module - 3rd Party Modules - Inductive Automation Forum
Just wanted to say thank you for making this module! Saved us a lot of time and headaches over here! Works perfectly!
Ditto - quick and easy to start using and works great
Automation Professionals is pleased to announce the production release of this Blob Server module for Ignition v8.3:
Blob Server v1.1.0.252721936 for Ignition v8.3.
This release is functionally identical the the corresponding v8.1 release:
Blob Server v1.1.0.231421939 for Ignition v8.1.
