I will admit that my wallet really wanted me to deploy this stuff inside my $$ driver modules.... But the universal approach was just too clean an implementation to lock down. I did make an ICC presentation pitch for Tag Actors as an advanced track topic.
Well I just donated, so I’m doing my part
You’ve certainly got my gears turning lol.
Now to cherry pick this into my v8.3 alpha....
I got you, Phil:
Awww!
I petition that Phil should be given a unique forum title of “Tag Actor”.
I'm not so sure I like that. What will newbies think? I already have a unique forum title....
No need to fight it!
Also, the bulk script action is a godsend for simplifying executing long-running tag value change scripts, especially when trying to explain how the original utilQueue library and its usage worked to people who come from simple HMI backgrounds
explaining why you can't just reach out to databases and do other long-running tasks within them was bad enough
Any goodies in there that haven't been mentioned in public yet? How polished is the alpha?
Sorry. No can do.
I figured. It would be neat/nice if a "pre-release" beta/alpha would be released to the Lounge for some of us regulars though, but I'm not hopeful that will happen.
I think last I checked I raised 160 bug topics last time they released v8.0. I'm sure others raised a lot as well both via the forums and official support channels. Probably not looking for a repeat ![]()
Updated BETA. Production Release. Fixes a bug in the module re-install life cycle that leaked everything. Also tweaked Tag Editor category text.
For Ignition v8.1: v2.1.0.250852036
I've pummeled this pretty thoroughly today, so this will probable be declared a production release soon.
New BETA. Alters the tags() function to not use the tags' own qualities for its function return quality. This enables other iterators to wrap tags() without using forceQuality(), which has the side effect of obliterating any nested non-good qualities. Adds the new qvAt() function which re-implements the square bracket operator to not discard nested qualities.
For Ignition v8.1: v2.1.1.250881822
You can now supply prune the list of returned tag path/value pairs to exclude non-good quality with this combination:
where(
tags({path.to.list.of.paths}),
isGood(qvAt(it(), 1))
Hey @pturmel, I'm trying to use system.util.runInGateway except i'm getting an exception however I try to use it, even with your example in your doco:
logger = system.util.getLogger(system.util.getProjectName() + '.' + system.reflect.getModulePath())
@system.util.runInGateway
def gwLogInfof(*args):
logger.infof(*args)
gwLogInfof('hello')
Java Traceback:
File "<input>", line 13, in <module>
java.lang.IllegalArgumentException: Unknown part '__main__' of function '__main__.gwLogInfof'
at com.automation_pros.simaids.gateway.ToolkitRPCImpl.runInGateway(ToolkitRPCImpl.java:89)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.ModuleInvoke.invoke(ModuleInvoke.java:167)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:435)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:523)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:590)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:86)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1410)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1665)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:598)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1580)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1553)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel$RequestDispatchable.dispatch(HttpChannel.java:1598)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:753)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:501)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:287)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:421)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:390)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:277)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.run(AdaptiveExecutionStrategy.java:199)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: Unknown part '__main__' of function '__main__.gwLogInfof'
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.PyTableCode.call(PyTableCode.java:182)
at org.python.core.Py.runCode(Py.java:1703)
at org.python.core.Py.exec(Py.java:1747)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.IllegalArgumentException: Unknown part '__main__' of function '__main__.gwLogInfof'
... 1 more
Are you putting all of that in the scripting console?
Everything but the last line needs to be in a project library script. The last line needs to be
someScript.gwLogInfof('hello')
The decorator only works on functions in project library scripts. (That have been saved.)
Ah, that would be it then. Yes I was just trying to run a function defined in the script console
I was just re-reading the documentation, and this statement seems pretty clear:
It must be a top level function in a Project Library Script. Not in site packages, nor a method nor any kind of nested function.
Sorry to disappoint you.
