I finally got back to this topic and found a solution. The key was finding the ImageLoader
function, which lets me find the original aspect ratio of the image regardless of however its currently scaled.
from com.inductiveautomation.ignition.client.images import ImageLoader
#Find Aspect Ratio of Component
imgComponent = system.gui.getWindow("Main Windows/General/Login").rootContainer.getComponent("Image")
imgComponentW = imgComponent.getWidth()
imgComponentH = imgComponent.getHeight()
imgComponentRatio = float(imgComponentW) / float(imgComponentH)
#Find Aspect Ratio of Original Image
filename = imgComponent.getPath()
img = ImageLoader.getInstance().loadImage(filename)
imgW = img.getWidth()
imgH = img.getHeight()
imgRatio = float(imgW) / float(imgH)
##Find Component Image Size in "% Bounds"
#if (imgComponentRatio >= imgRatio):
# fillW = 100
# fillH = int(fillW / imgRatio * imgComponentRatio)
#else:
# fillH = 100
# fillW = int(fillH * imgRatio / imgComponentRatio)
## Set Strech Mode to "% Bounds"
#imgComponent.setStretchMode(3)
#Find Component Image Size in "Pixel Size"
fillW = imgComponentW
fillH = int(fillW / imgRatio )
else:
fillH = imgComponentH
fillW = int(fillH * imgRatio )
# Set Strech Mode to "Parameters"
imgComponent.setStretchMode(2)
#Set Component Image Bounds
imgComponent.setStretchHeight(fillH)
imgComponent.setStretchWidth(fillW)
