It's probably still JAR related. Full stack trace to go along with the error would be useful.
Wrapper.log and Diagnostic logs seem to not show any relevant.
The two artifacts you listed in your pom.xml suggestion I can find in /home/admintest/.m2/repository/com/microsoft/azure, these JAR files has been moved to the ignition folde.r
I was recently trying to connect to an Azure SQL Server using the ActiveDirectoryServicePrincipal method, and this thread helped point me in the right direction, but for completeness I thought I would explain how I got it to work.
- Get
msal4jand all dependencies with Maven
- I used WSL for all of this which seemed easier than trying to do it on Windows directly
- Install jdk, I'm using
openjdk 11 - Download and unpack Maven, add to path
wget https://dlcdn.apache.org/maven/maven-3/3.9.8/binaries/apache-maven-3.9.8-bin.tar.gz
tar xzvf apache-maven-3.9.8-bin.tar.gz
mv apache-maven-3.9.8 /opt/
# Add mvn to path, I did this in my .zshrc
export PATH=$PATH:/opt/apache-maven-3.9.8/bin
- See Maven – Installing Apache Maven for latest version/instructions
- As @Kevin.Herron mentioned, create a temp folder with a
pom.xmlfile based on his post - I changed the version to the latest1.16.2 - Run
mvn install dependency:copy-dependenciesin the temp folder with thepom.xmlfile - This will create a new folder
target, all of the required.jarfiles will be intarget > dependency
- Copy all of the dependencies to
{IGNITION_PATH}/lib/core/gateway - You also need to put the
mssql-jdbc-auth-xxx.dllin the{IGNITION_PATH}/libfolder, you can get that directly from MSFT: Release notes - JDBC Driver for SQL Server | Microsoft Learn- Note I'm using the stock driver,
9.4.0
- Restart your gateway
- If you are using the stock
9.4.0driver, you will need to add some properties to the Extra Connection Properties section, here's how mine looks
databaseName={db_name};authentication=ActiveDirectoryServicePrincipal;AADSecurePrincipalId={clientId};AADSecurePrincipalSecret={clientSecret};
- You can leave the username and password blank
- If you are using a newer jdbc driver, you will need to put the
clientIdin theUsernamefield, and theclientSecretin thePasswordfield, and DO NOT add theAADSecurePrincipalIdorAADSecurePrincipalSecretproperties, otherwise it won't connect. - MSFT docs: Connect using Microsoft Entra authentication - JDBC Driver for SQL Server | Microsoft Learn.
Hope this helps someone out!
