Bad("Bad_NotWritable: The access level does not allow writing to the Node.")
FWIW @Kevin.Herron I’ve been seeing this specifically on 8.1.11 if I’m doing a fairly large logic change and a Logix PLC (not SLC) and then try and write to a tag while the logic changes are currently being accepted. It usually clears up a couple of seconds after the logic has been accepted into the PLC. Same error message.
