I'm not sure what you mean here. The target of your write, if an OPC tag, will get its timestamp when its own subscription notes the change you wrote. If your target is a memory tag, its new timestamp will be the time the write occurs. If you want to customize the timestamp written to a memory tag, you will need to construct a qualified value. See this topic:
