[Bug-11644] Gateway Receives Events For Missing Views
Sorry, to clarify: is there any ETA for the View onStartup and other View related events?
Additional question, the “script library [project].scriptName” executes on the gateway also for perspective and not on the client?
View onStartup script Actions should be working right now - it’s just that certain other actions (like Barcode Scanning) don’t work in View onStartup Events. The fix for this won’t be in for quite some time (I’d be very surprised if it’s in before the holidays).
As for the script question, you are correct; NO scripts run in Perspective Sessions - ALL Perspective scripts execute on the Gateway.
Just to clarify, this does not apply to the event handler scripting, correct?
Any piece of scripting (ie, where you’re writing Python code) is going to execute on the gateway - including session event handling.
thanks for clearing that up :slight_smile:
Thanks for your research into this, helped me navigate (pun not intended) around the issue in the Ignition Maker Edition 8.1.15 !
I've updated the Security Settings in the Project Properties to always require user authentication and increased the security level in the permission settings. As a result, the “received event for missing view” warning no longer appears.
Hope this solution works well for all of you.
