Right, but you’re supplying a Model.ShiftInstanceBreak object.
my_dict = dict()
my_dict['duration'] = 10
my_dict['name'] = 'Morning'
params = dict()
params['test_object'] = my_dict
system.perspective.openPopup("tLEtjaMm", "Test", params)
would send your data through.
Hi All, Is this problem solved? I’m on version 8.1.2 and I couldnt pass dataset as a parameter to a popup window.
Datasets as popup parameters was repaired in 8.1.4. (Bug #1083 for reference) See this post.
flavien
26
I have the same problem with jsonEncode function passing in an array variable to prepare an INSERT SQL.
Error concern the try statement.
jsonConfig = system.util.jsonEncode(config)
try:
insert_params=[
inputs['usage_basic']['title'],
inputs['usage_basic']['description'],
inputs['project_id'],
inputs['physical_output']['physical_id'],
inputs['usage_basic']['usage_basic'],
inputs['isUserUsage'],
inputs['service'],
jsonConfig
except:
return {'state':False,'message':u"Une variable d'insertion est manquante.","outputs":[], "meta":features.msgMeta(False)}
cols="("
values="VALUES("
insertCols=['title','description','project_id','physical_id','usage_basic','isUserUsage','service','config']
for col in insertCols:
cols=cols+col+","
values=values+"?,"
cols=cols[:-1]+") "
values=values[:-1]+")"
query="INSERT INTO admin.usages_used "+cols+values
usage_id=system.db.runPrepUpdate(query,insert_params,tx=txId,getKey=1)
