[BUG-14889] Error during blocking read of tags through scripting
@awalker,
We are experiencing the same issue with our runScript not working with expression tags. Should we try re-installing 8.0.6, or is there a proper fix for this problem?
Thanks!
Are you sure this is the same problem or do you just have an issue involving runBlocking?
Did you try the 8.0.7 nightly that was supposed to fix the original problem in this thread?
As for me, the 8.0.7 nightly has solved the problem
Our issue is with runScript only. Will try to upgrade again ASAP…
Thanks, the 8.0.7 RC1 fixed it!
@mgross, this issue is back in Ignition 8.0.13 :sob:
