Ignition 8.1.20
For Bacnet devices,
[System]Gateway/Devices//Enabled seem not to be sync with the device "Enabled" property displayed on gateway devices web page ?
Ignition 8.1.20
For Bacnet devices,
Weird… all device system tags share the same implementation that is unaware of the underlying device type. They are basically just looking at the common DeviceSettingsRecord. We’ll look into this.
note: device was created with system.device.addDevice.
I think I see what’s going on. Looks like this would be a bug with any device type, regardless of how they are created. There was a change that made it so when a device is edit/saved the system tags don’t get removed/added again unless the name changed, but it seems to have introduced this new bug.
Have there been any updates on this? I believe I'm experiencing a similar issue with Ignition 8.1.26 and a DNP3 device.
This should be fixed in 8.1.27.
Nice! Is there an estimate when the stable version will be released?
2023-04-25 if there are no delays.
