[BUG] page.props.primaryView
I use page.props.primaryView as binding to a label in a docked window (header).
However it is not always updating as expected.
One of the following 3 things happens:
1: it is updating
2: it is updating but with a big unexpected delay
3: it is not updating at all
Mostly of the times it is not updating at all.
However It is updating correctly when I configure a onclick method at de label with (only when I click with the mouse ofcourse):
self.refreshBinding(“session.props.theme”)
How is the theme even related to page.props.primaryView?
And why is the page.props.primaryView not updating at all?
Im using Ignition 8.0.8
I’m not able to replicate this issue, but I could look into it a bit further if you’d be able to provide me the Docked View you are using.
here is a docked view i am using:
  "custom": {},
  "params": {},
  "props": {
    "defaultSize": {
      "height": 90,
      "width": 1280
  "root": {
    "children": [
        "events": {
          "component": {
            "onActionPerformed": {
              "config": {
                "script": "\tsystem.perspective.navigate(\"/\")\n"
              "scope": "G",
              "type": "script"
        "meta": {
          "name": "Button Home"
        "position": {
          "basis": "100px"
        "props": {
          "image": {
            "height": 30,
            "icon": {
              "library": "material",
              "name": "home"
            "width": 30
          "style": {
            "backgroundColor": "#FFFFFF00"
          "text": ""
        "type": "ia.input.button"
        "events": {
          "dom": {
            "onClick": {
              "config": {
                "script": "\tself.refreshBinding(\"session.props.theme\")\n"
              "scope": "G",
              "type": "script"
        "meta": {
          "name": "Label Header"
        "position": {
          "basis": "20px",
          "grow": 1
        "propConfig": {
          "props.style.classes": {
            "binding": {
              "config": {
                "expression": "{session.custom.Styles.LabelStyle.Footer}"
              "type": "expr"
          "props.text": {
            "binding": {
              "config": {
                "path": "page.props.primaryView"
              "type": "property"
        "props": {
          "alignVertical": "center",
          "style": {}
        "scripts": {
          "customMethods": [],
          "messageHandlers": [
              "messageType": "Refresh",
              "pageScope": true,
              "script": "\t# implement your handler here\n\tself.refreshBinding(\"props.text\")",
              "sessionScope": false,
              "viewScope": false
        "type": "ia.display.label"
        "events": {
          "component": {
              "config": {
                "script": "\tif self.session.props.theme \u003d\u003d \"light\":\n\t\tself.session.props.theme \u003d \"dark\"\n\telse:\n\t\tself.session.props.theme \u003d \"light\" \t "
              "scope": "G",
              "type": "script"
        "meta": {
          "name": "Button ChangeTheme"
        "position": {
          "basis": "100px"
        "props": {
          "image": {
            "height": 30,
            "icon": {
              "name": "wb_sunny"
            "width": 30
          "style": {
          "text": ""
    "meta": {
      "name": "root"
    "propConfig": {
        "binding": {
          "config": {
            "expression": "{session.custom.Styles.Background}"
          "type": "expr"
    "props": {
      "style": {
        "overflow": "hidden"
    "type": "ia.container.flex"
another one i am using the same thing here:
  "custom": {},
  "params": {},
  "props": {
    "defaultSize": {
      "width": 250
  "root": {
    "children": [
        "meta": {
          "name": "FlexRepeater"
        "position": {
          "basis": "320px",
          "grow": 1
        "propConfig": {
          "props.instances": {
            "binding": {
              "config": {
                "parameters": {
                  "PageName": "{page.props.primaryView}"
                "queryPath": "GetMenuItems",
                "returnFormat": "json"
              "type": "query"
        "props": {
          "direction": "column",
          "path": "Templates/NavButton",
          "useDefaultViewWidth": false
        "type": "ia.display.flex-repeater"
    "meta": {
      "name": "root"
    "propConfig": {
      "custom.PrimaryView": {
        "binding": {
          "config": {
          "type": "property"
        "onChange": {
          "enabled": null,
          "script": "\tself.session.custom.HeaderTitle \u003d currentValue.value\n\tsystem.perspective.sendMessage(\"Refresh\")\n"
        "binding": {
          "config": {
            "path": "session.custom.Styles.Background"
          "type": "property"
    "props": {
      "style": {
        "paddingBottom": "5px",
        "paddingLeft": "5px",
        "paddingRight": "5px",
        "paddingTop": "5px"
I was not able to replicate the issue with the Views you provided. The second View was not a good View to attempt to replicate an issue with as it’s dependent on a query I obviously do not have. I replaced the query with one from my own environment, but without knowing what that query returns (content and size) I can only assume that my working query is close enough.
As for why the click event “fixes” your issue: It shouldn’t - you’re not even using the function correctly, and an examination of your Gateway logs will show you that clicking that Label is resulting in a script error being logged to the Gateway.
I see i made an error in the message handler indeed.
However the headertext is still taking a long time to update or not updating at all.
It is just a binding to page.props.primaryView
The strange thing is when I click a button (even without any function on it) the text will update, no matter if the button is on another docked window or just on the view or header itself.
I expect it to update immediatly because it is a property binding.
I will test it on another server within a few weeks (maybe the slow updates may be faster then).
In another project it works as it should be.
I will test it again with the project where it does not work on another server soon to see if that’s the problem
I am seeing the same behavior in 8.0.16
