[BUG?] Perspective Power Chart Bug - Embr-Chart as a Replacement?
It is something that also annoys me, so I do plan on seeing if I can override the placement without getting the weird thrashing behavior. It looks like there is a labelOffset option availble, will just need to see if I can configure a callback on it.
What does it look like with align: inner? I would expect that to align center for all the labels but with the “edge” labels aligned to the start/end of the chart.
IIRC it gives me the same issue, I'll have to check tomorrow.
Update: inner does keep the labels inside the bounds but the end labels start offset and then jump to the proper position when the tick is not the last tick on that side of the axis. Overall I didn't care for the behavior.
I'll probably just aim to mimic citect and chop the label
I have made the joyous discovery that vertically aligning in regards to the decimal (or whatever separator character you use) is not anything that can 'easily' be done.
I'll probably have to loop through all my formatted values in a box to see which one is the longest and pad the rest accordingly. Which sucks because that is yet another loop in my tooltip logic.
The other option I've seen is to split the float at the separator and place the integer value in one td and place the separator + decimal points in the next td element.
Ignition uses java's DecimalFormat under the hood. Which does not exist in any capacity in javascript. Custom functions all around! :loudly_crying_face:
If someone can provide a JavaScript function that converts a number to a string using the DecimalFormat convention, I can add it under global perspective namespace.
How about perspective.string.numberFormat(number, pattern)?
Best I could find was someone's 15 year old conversion of java's DecimalFormat to javascript at the time.
This would need to be accessible in the chart js context, since the tooltip is running in the external callback on the tooltip plugin. I'm also overriding the value formatter at the same time.
Yup, it absolutely would be. The global objects are added to the scope when the string in the property tree is converted into a proper function. It’s how the current perspective.context stuff is available.
Ah right, brain saw the perspective and assumed system.perspective. In that case that would absolutely be helpful, as I imagine others would want to be able to pass tag value formatting info/pattterns into the JS context and be able to use it.
How about Intl.NumberFormat() ?
Something like:
function numberFormat(number,local = "en-US",options = {}) {
   if (isNaN(number)) {
       return 'Invalid Input'; //Some more appropriate error handling obviously
    const formattedNumber = new Intl.NumberFormat(local,options).format(number)
    return formattedNumber
Input:
console.log(numberFormat(12.3457))
console.log(numberFormat(12.3457,"da-DE",{style:"unit", unit:"liter", unitDisplay:"short", maximumFractionDigits:2}))
console.log(numberFormat(12.3457,"da-DE",{style:"unit", unit:"liter", unitDisplay:"long", maximumFractionDigits:2}))
Output:
 >"12.346"
 >"12,35 l"
 >"12,35 liter"
This would allow you to use local to, it's not as convenient as just giving it a pattern, but is arguably more flexible.
Of course you could also do something like this:
Not my code, and not tested so take with a grain of salt
function formatDecimal(number, pattern) {
    return 'Invalid Number';
  const parts = pattern.split('.');
  let integerPart = parts[0];
  const decimalPart = parts[1] || '';
  const numberString = number.toFixed(decimalPart.length);
  const [integerNum, decimalNum] = numberString.split('.');
  let formattedInteger = '';
  let integerIndex = integerNum.length - 1;
  let patternIndex = integerPart.length - 1;
  while (integerIndex >= 0) {
    formattedInteger = integerNum[integerIndex] + formattedInteger;
    integerIndex--;
    patternIndex--;
    if (patternIndex >= 0 && integerPart[patternIndex] === ',') {
      formattedInteger = ',' + formattedInteger;
  const formattedDecimal = decimalNum ? '.' + decimalNum : '';
  return formattedInteger + formattedDecimal;
The goal was to be able to take the format defined on the tag (or somewhere else in Ignition) and have it apply to the chart display labels.
I'm trying to make configuring tags for charts of this type as easy as possible (minimal js setup other than the main driving logic I have).
Its the difference between configuring an Int.NumberFormat for every tag or format that I'm using for the tags and then trying to correlate which dataset gets which Intl.NumberFormat vs just pulling the number format as defined by base Ignition and passing that through.
Obviously if we had a helper function that would probably be doing the Intl.NumberFormat stuff behind the scenes.
Edit: I just realized that Ignition base gets around this because they process the value and formatting in Java before passing the formatted string to whatever JS they use on for displaying the perspective page/view.
Format control aside I have arrived at something that i think is 'decent'. I also tweaked my side decision logic to be sticky, so if I flipped the side that the tooltip was on, it stays on that side until it has enough space to go back to the other side, instead of always starting on the right and then deciding.
This also let me catch a transform declaration on the tooltip div that was messing with math and sizing. Overall much less jumpy box sizing and placement.
Labels, Process Values and Engineering units each have their own style class defined and applied, so you can tweak them via style classes in Ignition.
Tabled Tooltip
One longstanding issue I have is that if I pan a large amount, the tooltip snaps to the last point way off screen and I get a huge scroolbar. (:squinting_face_with_tongue:)
Edit: Managed to fix the scroolbar issue. Had to just do a very early check to see if the tooltip caret location was inside the viewbox and delete the tooltip elements if it wasn't. I still occasionally get a single flicker of scrollbar near the right edge of the screen but I can't nail down when it happens.
Yet Another Edit:
Updated tooltip code for anyone who wants to play around with it.
Updated External Tooltip Handler
(context) => {
	// Helper function to get current locale separator character
	// separator types are decimal or group
	const getSeparator = (locale, separatorType) => {
		const numberWithGroupAndDecimalSeparator = 10000.1;
		return Intl.NumberFormat(locale)
			.formatToParts(numberWithGroupAndDecimalSeparator)
			.find(part => part.type === separatorType)
			.value;
	const getOrCreateTooltip = (chart, axisId) => {
		let tooltipId = "tt_" + axisId;
		let tooltipEl = chart.canvas.parentNode.querySelector('div #' + tooltipId);
		if (!tooltipEl) {
			tooltipEl = document.createElement('div');
			tooltipEl.id = tooltipId;
			tooltipEl.classList.add('psc-trendsurfer\/Tooltip\/container'); // Your custom style here
			tooltipEl.style.opacity = 1;
			tooltipEl.style.pointerEvents = 'none';
			tooltipEl.style.position = 'absolute';
			tooltipEl.style.transition = 'all .1s ease';
			tooltipEl.style.fontSize = '12px';
			let tooltipBody = document.createElement('div');
			tooltipBody.id = tooltipId + '_body';
			tooltipBody.classList.add('psc-trendsurfer\/Tooltip\/body');
			let tooltipTable = document.createElement('table');
			tooltipTable.id = tooltipId + '_item_table';
			tooltipTable.style.tableLayout = 'fixed';
			tooltipTable.style.borderCollapse = 'collapse';
			tooltipTable.classList.add("psc-trendsurfer\/Tooltip\/table");
			let tooltipTableBody = document.createElement('tbody');
			tooltipTable.appendChild(tooltipTableBody);
			tooltipBody.appendChild(tooltipTable);
			tooltipEl.appendChild(tooltipBody);
			chart.canvas.parentNode.appendChild(tooltipEl);
		return tooltipEl;
	const getFormattedValueParts = (itemValue) => {
		let separatorNdx = itemValue.lastIndexOf(localeSeparator);
		let itemIntStr = '';
		let itemDecStr = '';
		if (separatorNdx !== -1) {
			itemIntStr = itemValue.substring(0, separatorNdx);
			itemDecStr = itemValue.substring(separatorNdx + 1);
		} else {
			itemIntStr = itemValue;
			itemDecStr = '';
		// if decimal portion is not blank then re-insert the separator char
		if (itemDecStr !== '') {
			itemDecStr = localeSeparator + itemDecStr;
		return {itemIntStr: itemIntStr, itemDecStr:itemDecStr}
	const createTooltipItem = (tooltipItem, ndx) => {
		let colors = tooltip.labelColors[ndx];
		let {boxHeight, boxWidth} = tooltip.options;
		let itemLabel = tooltipItem.dataset.label || 'Dataset ' + tooltipItem.datasetIndex;
		itemLabel += ':';
		let itemEngUnit = tooltipItem.dataset.engUnit || '';
		let {itemIntStr, itemDecStr} = getFormattedValueParts(tooltipItem.formattedValue);
		const colorBlock = document.createElement('span');
		colorBlock.classList.add('psc-trendsurfer\/Tooltip\/Item\/Indicator'); // Your custom style here
		colorBlock.style.background = colors.backgroundColor;
		colorBlock.style.borderColor = colors.borderColor;
		colorBlock.style.borderWidth = '2px';
		colorBlock.style.borderStyle = 'solid';
		colorBlock.style.marginRight = '10px';
		colorBlock.style.height = boxHeight + 'px' || '12px';
		colorBlock.style.width = boxWidth + 'px' || '12px';
		colorBlock.style.display = 'inline-block';
		const tr = document.createElement('tr');
		tr.style.backgroundColor = 'inherit';
		tr.style.borderWidth = 0;
		tr.classList.add('psc-trendsurfer\/Tooltip\/Item\/Item');// Your custom style here
		const colorTd = document.createElement('td');
		colorTd.style.borderWidth = 0;
		colorTd.appendChild(colorBlock);
		const labelTd = document.createElement('td');
		labelTd.style.borderWidth = 0;
		labelTd.classList.add('psc-trendsurfer\/Tooltip\/Item\/Label');// Your custom style here
		labelTd.appendChild(document.createTextNode(itemLabel));
		const valueIntTd = document.createElement('td');
		valueIntTd.style.borderWidth = 0;
		valueIntTd.style.paddingLeft = '2px';
		valueIntTd.style.textAlign = 'right';
		valueIntTd.classList.add('psc-trendsurfer\/Tooltip\/Item\/Value');// Your custom style here
		valueIntTd.appendChild(document.createTextNode(itemIntStr));
		const valueDecTd = document.createElement('td');
		valueDecTd.style.borderWidth = 0;
		valueDecTd.style.paddingRight = '2px';
		valueDecTd.style.textAlign = 'left';
		valueDecTd.classList.add('psc-trendsurfer\/Tooltip\/Item\/Value');// Your custom style here
		valueDecTd.appendChild(document.createTextNode(itemDecStr));
		const engUnitTd = document.createElement('td');
		engUnitTd.style.borderWidth = 0;
		engUnitTd.classList.add('psc-trendsurfer\/Tooltip\/Item\/Unit');// Your custom style here
		engUnitTd.appendChild(document.createTextNode(itemEngUnit));
		tr.appendChild(colorTd);
		tr.appendChild(labelTd);
		tr.appendChild(valueIntTd);
		tr.appendChild(valueDecTd);
		tr.appendChild(engUnitTd);
		return tr;
	const updateOrAddTooltipItem = (table, item, ndx, groupNdx) => {
		let tableBody = table.querySelector('tbody');
		let itemEl = null;
		if (groupNdx >= table.rows.length) {
			while (table.rows.length <= groupNdx) {
				itemEl = createTooltipItem(item, ndx)
				tableBody.appendChild(itemEl);
		} else {
			let {itemIntStr, itemDecStr} = getFormattedValueParts(item.formattedValue);
			let itemLabel = item.dataset.label || 'Dataset ' + item.datasetIndex;
			itemLabel += ':';
			let itemEngUnit = item.dataset.engUnit || '';
			itemEl = table.rows.item(groupNdx);
			let itemRow = table.rows[groupNdx];
			// Update color block for item
			let colorBlock = itemRow.cells.item(0).firstChild;
			// Set updated values for item
			itemRow.cells.item(1).textContent = itemLabel;
			itemRow.cells.item(2).textContent = itemIntStr;
			itemRow.cells.item(3).textContent = itemDecStr;
			itemRow.cells.item(4).textContent = itemEngUnit;
		return itemEl;
	const localeSeparator = getSeparator(navigator.language, 'decimal');
	const {chart, tooltip} = context;
	const {height, width} = chart.canvas;
	const {caretSize, padding, minWidth} = tooltip.options
	const {caretX, caretY, opacity} = tooltip;
	const isOnScreen= (caretX <= width) && (opacity == 1);
	let flipTipSide = context.chart.canvas.lastToolFlipped || false;
	const usedScales = [];
	const tooltips = [];
	const itemsByParent = {};
	let topScaleId = null;
	let scaleWeight = 0;
	let widestTTItem = 0;
	if (!tooltip || !tooltip.dataPoints) {return};
	// Build fake tooltip for sizing checks
	const ruler = getOrCreateTooltip(chart, '__ruler');
	ruler.style.padding = padding + 'px ' + padding + 'px';
	const rulerTable = document.createElement("table");
	rulerTable.style.tableLayout = 'fixed';
	rulerTable.style.borderCollapse = 'collapse';
	rulerTable.classList.add("psc-trendsurfer\/Tooltip\/table");// Your custom style here
	ruler.querySelector('div').append(rulerTable);
	const rulerTableBody = document.createElement('tbody');
	rulerTable.appendChild(rulerTableBody);
	ruler.style.left = '5px';
	// But only spawn it if we are going to be drawing the tooltip
	if (isOnScreen) {
		chart.canvas.parentNode.appendChild(ruler);
		// Check size of title
		let titleEl = document.createElement('span');
		titleEl.classList.add('psc-trendsurfer\/Tooltip\/title');// Your custom style here
		titleEl.appendChild(document.createTextNode(''));
		ruler.insertBefore(titleEl, ruler.childNodes[0]);
		let itemWidth = Math.ceil(ruler.offsetWidth) + 2;
		ruler.removeChild(titleEl);
		if(itemWidth > widestTTItem) {widestTTItem = itemWidth}
	} else {
		chart.canvas.lastToolFlipped = false;
	tooltip.dataPoints.forEach( (element, ndx) => {
		let scaleId = element.dataset.yAxisID || 'y';
		let tooltipId = 'tt_' + scaleId;
		/* If the axis Id is not in the used Ids list
		* then other items that use it as a key do not exist
		* So create them as soon as we see a new axis id
		* If the tooltip is not on screen, delete existing
		* if it exists */
		if (!usedScales.includes(scaleId)) {
			usedScales.push(scaleId);
			itemsByParent[scaleId] = 0;
			// If the tooltip is not on screen and exists, delete it
			if (!isOnScreen){
				if (tooltipEl) {
					chart.canvas.parentNode.removeChild(tooltipEl)
				return;
			// Determine if scale is the top most scale
			if (chart.scales[scaleId].weight > scaleWeight) {
				scaleWeight = chart.scales[scaleId].weight;
				topScaleId = scaleId;
			let tooltipEl = getOrCreateTooltip(chart, scaleId);
			// apply padding changes
			tooltipEl.style.padding = padding + 'px ' + padding + 'px';
			// Stuff element into array to fetch easier later
			tooltips.push(tooltipEl);
		} else if (!isOnScreen) {return}
		let localGroupItemNdx = itemsByParent[scaleId];
		let tooltipEl = tooltips[usedScales.indexOf(scaleId)];
		let tooltipBodyEl = tooltipEl.querySelector('div #'+ tooltipId + '_body');
		let tooltipItemTable = tooltipBodyEl.querySelector('#'+ tooltipId + '_item_table');
		// Update the values for the items in the tooltip body or add them if they are missing
		// clone the returned item to let us use it for measurements
		let itemEl = updateOrAddTooltipItem(tooltipItemTable, element, ndx, localGroupItemNdx).cloneNode(true);
		// measurements
		rulerTableBody.appendChild(itemEl);
		rulerTableBody.removeChild(itemEl);
		// compare measured width will all time largest
		if (itemWidth > widestTTItem) {widestTTItem = itemWidth}
		itemsByParent[scaleId] ++;
	if (!isOnScreen) {
		chart.canvas.parentNode.removeChild(ruler);
		return;
	// remove ruler
	// calc minimum size
	const widestItemWidth = ((widestTTItem > minWidth) ? widestTTItem : minWidth);
	let expectedX = caretX + caretSize;
	let expectedRight = expectedX + widestItemWidth;
	let flippedTipExpectedX = (caretX - caretSize - widestItemWidth)
	// Sticky tooltip side switching
	if ((!flipTipSide) && (expectedRight >= (chart.chartArea.right - 5))) {
		flipTipSide = true;
		context.chart.canvas.lastToolFlipped = true;
	} else if ((flipTipSide) && (expectedRight <= (chart.chartArea.right - 20))){
		flipTipSide = false;
		context.chart.canvas.lastToolFlipped = false;
	// loop for final placement and title addition
	usedScales.forEach( (element, ndx) => {
		let tooltipEl = tooltips[ndx];
		let tooltipItemCount = itemsByParent[ndx];
		let tooltipId = 'tt_' + element;
		// Grab associated scale
		let scale = chart.scales[element] || null;
		if (!scale) {return}
		// Tooltip placement
		let expectedY = (scale.top + 10);
		tooltipEl.style.top = expectedY + 'px';
		if (flipTipSide) {
			tooltipEl.style.left = flippedTipExpectedX + 'px';
		} else {
			tooltipEl.style.left = expectedX + 'px';
		// See if we have more items in the item table than items used this pass
		let tooltipTableBody = tooltipItemTable.querySelector('tbody');
		// If we have more items than we touched, remove the extras
		if (tooltipItemTable.rows.length - 1 > tooltipItemCount) {
			while (tooltipItemTable.rows.length > tooltipItemCount) {
				tooltipTableBody.lastChild.remove()
		// Add title element to top most tooltip
		let titleEl = tooltipEl.querySelector('#tt_'+element+'_title')
		if (element === topScaleId) {
			if (!titleEl) {
				titleEl.id = 'tt_'+element+'_title';
				tooltipEl.insertBefore(titleEl, tooltipEl.childNodes[0]);
			titleEl.textContent = tooltip.title[0];
		} else if (titleEl) {
			tooltipEl.removeChild(titleEl);
Another™ Edit:
So tick label placement handling is terrible. You have to leave them visible, but make the text transparent, and then add a custom plugin to iterate through the list of generated ticks and draw them where you want in the afterDraw event call.
But hey, at least tick labels are centered on ticks and I don't have varying amounts of my chart cut off the right side.
Corrected Tick Labels
afterDraw callback
(context) => {
	let ctx = context.ctx;
	let myAxis = context.scales.x;
	myAxis.ticks.forEach((tick, ndx) => {
		let xPos = myAxis.getPixelForTick(ndx);
		let yPos = myAxis.top + 20;
		// draw tick
		ctx.save();
		ctx.textBaseline = 'middle';
		ctx.textAlign ='center';
		ctx.fillStyle = '#666';
		ctx.fillText(tick.label, xPos, yPos);
		ctx.restore();
I also got annoyed with the ticks so I started and finished my partial polling logic so I don't fetch the whole span if the user has panned over a small amount or if the user has zoomed into an area and the granularity did not change.
