When I create a text object and create a binding with unicode characters it looks as I would expect
binding:
return u'({}{})'.format(u'▼' if value < 0 else u'▲', abs(value))
When I embed that view in another view it seems that the unicode text gets converted to non-unicode
but… this only happens in the designer. It looks like I would expect in a client.
I spent more time than I’m willing to admit trying to “fix it” before realizing it worked like it should in the client and is only an issue in the designer.
Hello Matthew, I was able to reproduce the same display issue with your example. I would suggest contacting Support to have the behavior reviewed and reported. Thanks! https://inductiveautomation.com/support/home/
